neutral safety switch
Old Sep 29, 2012 | 02:24 PM
sd concepts's Avatar
I am looking for a neutral safety switch for my 85 camaro z28 with a 5 speed transmission. No parts stores have one and i can't even seem to find a picture of one. can someone help me out.
Old Sep 29, 2012 | 02:26 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: neutral safety switch
I would try either a junkyard or a Chevy dealer...
Have you positively identified it as bad? If not, they are really easy to test. You could also order one from Rock Auto... I ordered a few switches from them with great results and quick shipping.
Old Sep 29, 2012 | 02:28 PM
Well this car wa under alot of water, and in the rebuild process, it used to be an automatic and now has a six speed in it. and in order to make this vehicle pass tech it needs it. just seems like the easy parts are the hardest to find
Old Sep 29, 2012 | 02:30 PM
nothing on rock auto
Old Sep 29, 2012 | 02:40 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Did you swap using 4th gen pedals? I purchased my Neutral Safety switch from Hawks. Not sure if the 3rd gen pedals use the same switch as the 4th gen pedals.
http://www.hawksthirdgenparts.com/pr...-Firebird.html
My pedals came with it, and I was upset I wasted money on the switch... until I went to start my car and found a faulty NSS... Haha
This thread has pictures along with part numbers for 3rd gen pedals.
https://www.thirdgen.org/forums/elec...l-neutral.html
Old Sep 29, 2012 | 04:43 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
FWIW, if you cannot find one, you can easily make one yourself. You need a switch that can handle 30 amps and activates when pushed. Install it on the pedal assembly in a way so that it is activated when the clutch pedal is fully depressed to the floor (disconnect the clutch master rod for that test to make it easier).
Hope this helps.
Lou
MM2Robinson
Oct 1, 2017 09:16 AM
Veaceonee
Sep 29, 2016 08:15 PM
Stroopwafel
Sep 11, 2015 06:38 AM
Randomtask2
Sep 10, 2015 08:37 AM
Fronzizzle
Sep 8, 2015 12:10 PM
