High Beam dash light issue....
Old Sep 29, 2012 | 06:33 PM
iroczz4's Avatar
Car: 1987 Iroc w/ t-top
Engine: Originally L98 currently ZZ4 crate
Transmission: Original 700R4
Hello, new to the site but not third gens, I initially thought my highbeam dash light (blue) was burnt out but now seems to work periodically, not sure what the issue is, ground, loose wire? I've tried the search engine on here but can't seem to find anything, any help greatly appreaciated!
Old Oct 1, 2012 | 04:28 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Bluelighted
Could be a loose bulb, a bulb with a broken filament that occasionally makes contact, an intermittent in the printed circuit board trace to the socket.
You failed to mention the year of the car therefore we will just give you a general idea where the wire for that is.
In one of the dash connectors you will find a
light green wire.
That wire comes from the dimmer stalk and goes to hi-beam indicator.
So before you take apart the dash you can make sure that connector is fully seated.
Happy Racing!
How Come Some Drivers On The Street Don’t Know How To Make A Turn In One Direction Without Starting By Turning In The Opposite Direction?
Old Oct 1, 2012 | 05:58 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Re: High Beam dash light issue....
As a new member, you should read this as well: https://www.thirdgen.org/forums/tech...formation.html
Old Oct 1, 2012 | 06:37 PM
iroczz4's Avatar
Sorry about that, it's an 87 Iroc.....and profile being updated as I type! Thanks for the info
1992CamaroGirl
Dec 25, 2017 08:45 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
tnrednneck
Aug 13, 2015 08:57 AM
apie2546
Aug 8, 2015 07:12 AM
