little black plug in beside battery
Old Oct 2, 2012 | 07:28 PM
SBCsonoma91's Avatar
Car: 1987 Trans Am
Axle/Gears: 3.08 :(
What is that little black blox that the battery plugs in to right in between the battery and radiator on an 87 trans am TPI? I rewired my electric fans to a toggle switch and now the car wont start. the fuel pump isnt turning on when I turn the key to accessory. I tested it by running a wire from the battery to the ALDL and the pump turned on. I stole the power from that little "black box" for my fans, and im wondering if this has anything to do with why it wont start?
Old Oct 3, 2012 | 09:49 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: little black plug in beside battery
The "little black box" is actually a single fuse holder. This is the fuse for the ECM memory and the fuel pump circuit.
Do NOT power the fans from this fuse since you will exceed the current rating for the fuse and the wires.
You must turn the key all the way to On to hear the fuel pump prime, Accessory is not enough, it only powers the radio.
And there is no need to run power straight to the fans, they both have relays to take care of switching the high-amp circuit. You just need to ground the relays to make the fans come on. Do a search here, there are plenty of people who are taking over the control of their cooling fans.
Old Oct 3, 2012 | 03:48 PM
Car: 1987 Trans Am
Axle/Gears: 3.08 :(
The fans stopped working and I had an overheat, so I just wired it to a switch so i could turn it on at will.
Old Oct 3, 2012 | 06:12 PM
BigBadLou's Avatar
Engine: TPI
It is preferred and smarter to correct the electrical problem rather than bypass it. Now you must always remember to turn the fan on and off as the engine heats up and cools down. The ECM provides that functionality for you so that you can concentrate on driving, instead of flipping switches.
A nice article to help you troubleshoot and fix the cooling fan circuit:
http://www.austinthirdgen.org/index.php?pid=36
Hope this helps.
Lou
Old Oct 3, 2012 | 06:56 PM
Car: 1987 Trans Am
Axle/Gears: 3.08 :(
Hope this helps.
Lou
Do I need to turn it off while driving? Or can I just let it run and then turn it off when i stop?
Old Oct 3, 2012 | 07:35 PM
BigBadLou's Avatar
Engine: TPI
Normally, the fans are not needed if the vehicle speed is above 42 mph (IIRC), which is what the ECM normally takes care of for you.
I would strongly recommend troubleshooting and fixing the cooling fan circuit because it will make it so much easier for you. I myself would hate to be driving around with a burning thought in the back of my head "what did I forget??" and then look down at my temp gauge and see it in the red and cook the engine.
Old Oct 3, 2012 | 07:49 PM
Car: 1987 Trans Am
Axle/Gears: 3.08 :(
My small block swap s10 is always running hot so I have a knack for always keeping an eye on the temp gauge haha, its kind of a nervous habit. My main problem right now is trying to get the car to run. Ive now been told that the black plug is just a fuel pump tester. What fuse in the block is for the FP?
Old Oct 3, 2012 | 08:24 PM
BigBadLou's Avatar
Engine: TPI
There is no FP fuse in the fuse block. As I mentioned before, the fuel pump circuit is powered from that single-fuse holder by the battery. If you were told that it's a tester, that is incorrect information. If it has a red and orange wire and a slot for a standard blade fuse, that's your FP fuse.
Old Oct 3, 2012 | 08:31 PM
Car: 1987 Trans Am
Axle/Gears: 3.08 :(
What amperage of fuse is required?
Old Oct 3, 2012 | 08:33 PM
BigBadLou's Avatar
Engine: TPI
20 amps, sir.
Old Oct 3, 2012 | 08:47 PM
Car: 1987 Trans Am
Axle/Gears: 3.08 :(
thank you sir. I hate electrical components. If i had my way every v8 would be carbed!
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
colton_carlson
Mar 8, 2019 12:21 PM
