vats module for 91 camaro
Old Oct 8, 2012 | 05:04 PM
chevyboyfresh's Avatar
Car: 1991 chevy camaro convertible RS
Engine: 350 tbi
so the dealer wants 320$ dollars for it which is rediculous the reason I need one is it some how went bad after having the battery disconnected for two months while redoing my heads since it was my first time it took me some time but none the less here I am need to fix this any recomendations for an aftermarket vats module I can use ?
Old Oct 10, 2012 | 01:53 PM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
Re: vats module for 91 camaro
I have a 91 Camaro. I got stuck at work one day because of Vats. This worked for me. I took down the knee bolster and you will see 2 wires (orange and white) coming form the steering column. This connects to the VATS. I unplugged it and cut the plug that runs underneath the dash towards the VATS module. NOW, before you do that, take a multimeter and check the resistance of the chip on the key. One test lead on one side of the chip and the other test lead on the other side. Mine was like 10k ohms, I believe. Get a resistor thats around 5% tolerance either way and put one resistor lead on the orange wire and the lead on the white wire. If you measured correctly, you car should start thinking it has the right key in all the time. You can get creative with the resistor and make a nice valet plug out of it
Old Oct 11, 2012 | 06:25 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
There are no aftermarket module options if the module is faulty
You delete VATS by having it taken out in the tune or install a device
http://www.bakerelectronix.com/products_vats/
to generate the correct signal needed by the computer
Both ways require the starter relay to be bypassed
You could try for a used VATS module at the junkyard but would need a new key to match it . Are 15 different key combos ( that can't be changed )
https://www.thirdgen.org/vats_passkey_system
Old Oct 11, 2012 | 06:29 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Usual remedy but if the VATS module itself is faulty then resistors will do little as the module has to be working correctly to read them
Old Oct 11, 2012 | 06:34 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
it some how went bad ?
What is your problem ;
no cranking over
or no fire up
What tests have you done to prove it is the module itself ???????
Have you tried jumping the starter solenoid ( so it cranks over ) to see if it will fire up ?
Vats has 2 parts ;
if the starter ( crank ) part is faulty then bypassing the starter relay solves that problem without replacing anything
Frozer!!!
Jan 19, 2024 04:55 PM
db057
Aug 22, 2015 08:17 PM
stalkier
Aug 13, 2015 12:59 PM
djmarch
Aug 9, 2015 05:27 PM
