not a thirdgen, but help
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
my brothers 94 camaro, where the hell is the vats box located, we've damn near got the dash completely out and cant find it, but we're replacing the column because the previous owners bypassed the vats box (and did a real shitty job) so now it starts only when it wants to any help will be appreciated, we know what it looks like since we have a new one ready to go in but the only info i've been able to find on it is "right of the radio" so far
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: not a thirdgen, but help
Since TGO is a thirdgen site, as you well know, I'd suggest a site like the following for specific info about a fourthgen:
http://www.camaroz28.com/
Best of luck to your brother and his 94.
JamesC
JamesC
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
It's mounted on the Pass side air bag bracket assembly.
step 1 remove or disconnect Instrument panel
step 2 removed screws retaining VATS module to air bag bracket assembly
Step 3 unplug
IIRC I'm pretty sure the VATS relay is on the far pass side behind the dash.
Good luck !
Step 3 unplug
Good luck !
Car: 64 Studebaker Avanti,67 ElCaminoTBI
Engine: GM 350 10.5:1 Supercharged
Axle/Gears: 3.54 posi
The last one I did was way above the radio, near center
Terrell351
Jun 13, 2021 01:13 PM
