Question regarding the headlight switch / Trip Meter
Old Nov 5, 2012 | 02:32 PM
Mitchemracing4's Avatar
Car: 92 25th Anv. Edition Camaro
Engine: 5.0 305 c.i.
Transmission: Standard Automatic
Axle/Gears: Standard
Hi guys , I have a couple of questions . Hopefully simple . I have a 1992 5.0 L RS . My Odometer and Trip Suddenly stopped working . Any idea on the cause ? The RPM has been pegged for sometime so I decided to just switch out a Cluster from a 91 RS I had . (RPM pegged on that as well , as with most of these models) . Anyway during the switch I broke the little plastic piece that holds the Headlight switch in place . I also noticed that the pull switch itself would not go into the main switch easily so I went and stole the switch out of my 91 . After bolting it all back together I was holding the switch in place while I made sure the connectors were all tight and noticed it was very hot . I took it out , plugged the older switch in and same thing . So is it normal for this to get hot or is something not grounding ? I checked and did not find any wires disconnected other than what I think would be the harness for the factory fog lights (mine did not come with them). Headlights work fine High and low beams . Just curious so I don't have my lights go out during the night or have a fire .
Thanks for your help .
Ghettobird52
Jul 5, 2024 11:18 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
tnrednneck
Aug 13, 2015 08:57 AM
