vats system
Old Nov 22, 2012 | 06:59 PM
82xCAMAROxZ28's Avatar
Car: 85 iroc tpi t-top
Engine: 383 tpi
Transmission: built 700r4
Axle/Gears: 4.56
vats system
how can i get rid a my vat system in my car
Old Nov 22, 2012 | 07:33 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: vats system
The best is to disable it on the ECM chip.
But does your car even have VATS? Your profile says 1982 Z28. The Camaros did not get VATS until 1990.
Old Nov 22, 2012 | 11:40 PM
Engine: 383 tpi
Axle/Gears: 4.56
Re: vats system
its another camaro im working on but it an 89 but has the the key with the resister in it
Old Nov 23, 2012 | 05:20 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: vats system
How much do you want to get rid of?
Just the key reader or the complete system?
You can put a resistor on the wiring that will make the VATS module "think" the correct key is being used
https://www.thirdgen.org/vats
or as stated you can get the VATS function deleted on the memcal (tune ) which removes VATS completely
http://pcmforless.com/index.php?opti...=109&Itemid=29
You can also install a device that supplies the correct fuel enable signal required by the computer
http://www.bakerelectronix.com/products_vats/
Either way will require you to manually bypass the starter relay also controlled by VATS for VATS to be completely gone
Old Nov 23, 2012 | 01:14 PM
Engine: 383 tpi
Axle/Gears: 4.56
Re: vats system
well idk.. im swith to carburated and want to know if i have to get rid of the vats
Old Nov 23, 2012 | 01:23 PM
BigBadLou's Avatar
Engine: TPI
Re: vats system
If you are switching to a carburetor, you will be removing the ECM which uses VATS. Thus, VATS will be defeated by removal.
The only thing you will need to do, as vetteoz already pointed out, is bypass the Starter Enable Relay but that's just a 5-minute fix. Just ground the thin black/yellow on the relay and you are good to go.
Old Nov 23, 2012 | 06:49 PM
salfirebird92's Avatar
Car: 92 Firebird Formula
Engine: 5.0 V8
Re: vats system
Here you go bro I had problem with mine starting so I did this and it works and have not gave problems ever since hopefully it helps you
Old Nov 23, 2012 | 07:51 PM
Engine: 383 tpi
Axle/Gears: 4.56
Re: vats system
Thanks Guys.. BigBadLou vetteoz salfirebird92
Old Nov 25, 2012 | 06:57 AM
Engine: 5.0 V8
Re: vats system
Np did you get it to work
Old Dec 15, 2012 | 07:45 PM
camaro_rs87's Avatar
Car: 87' Camaro and 92'
Engine: 2.8L and 3.1L
Re: vats system
okay so i need to know how to test the chip in the key. i tried with a mulitmeter with the switch set on 20k and only got .002 and on 2000 setting i only got .10. what does that mean? all i need to do is find the resistance cuz i already bypassed the start enamble relay.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Winchester1094
Sep 15, 2015 09:48 AM
383cam
Sep 9, 2015 06:01 AM
studebaker60
Sep 7, 2015 12:36 PM
