Which are high beams with are low?
Old Dec 31, 2012 | 07:00 PM
Valtyr's Avatar
Car: 1984 z28HO
Engine: 305HO
Hi guys I just recently bought a 1984 z28 but the inner lights don't work are they the high beams or the low beams?
Old Dec 31, 2012 | 08:10 PM
z28_87Camaro's Avatar
Car: 1987 Z28 / 1988 IROC-Z
Engine: 305 LG4 / 305 LB9
Transmission: T5 5spd
Axle/Gears: 3.42 / 3.08
Re: Which are high beams with are low?
Your highbeams are the inner. When you turn your highbeams on, the inner lights turn on WITH your lows.
Old Dec 31, 2012 | 08:22 PM
Valtyr's Avatar
Car: 1984 z28HO
Engine: 305HO
I'm not sure if i am missing something but when i pull the switch for my lights once no lights come on and when I pull it twice only the lows are on. Is the high beam switch somewhere else? If so where? Really wish i had an owners manual lol
Old Dec 31, 2012 | 09:56 PM
kentuckyKITT's Avatar
Car: 2 T-Tops
Engine: 327/305
Transmission: TH350/700R4
Axle/Gears: 3:42/2:73
I'm not much on Camaros...more of a Firebird guy, but if you have a pull **** for headlights, usually, part way out is parking lights, all the way out is low beam headlights. To activate high beams, you pull back the turn signal lever toward you and it will click. I'm just guessing here as it's been a long time since I've had a Camaro, but I'm pretty sure that's how it was.
Old Dec 31, 2012 | 10:01 PM
Valtyr's Avatar
Car: 1984 z28HO
Engine: 305HO
Man i feel really stupid now LOL I could have sworn i tried that and it wasn't going back at all hahahaa but i just tried it and it works Thanks guys
Old Dec 31, 2012 | 10:06 PM
Valtyr's Avatar
Car: 1984 z28HO
Engine: 305HO
One more question I have is how do you turn on the power antenna is it supposed to come on with the radio? Or is it a switch?
Old Jan 1, 2013 | 06:46 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Yes.
JamesC
Old Jan 2, 2013 | 06:21 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
You Deserve A Raise
how do you (raise) the power antenna is it supposed to come on with the radio?
If it’s the stock radio, yes.
To test the antenna motor gain access to the antenna motor connector at the back of the radio.
It’s the connector with three terminals.
With that connector unplugged, ground the
gray wire, and apply power to the green wire.
If the antenna is good it will raise.
Next, this time ground the
green wire, and apply power to the
White wire.
If the antenna is good it will retract.
Happy Racing!
I Didn’t Wreck, The Track Moved
Old Jan 2, 2013 | 11:28 PM
Valtyr's Avatar
Car: 1984 z28HO
Engine: 305HO
The PO put in an after market radio and I think he just left it disconnected, at least thats what it looked like when i pulled it out but i will check the antenna before trying to hook it back up thanks nina
db057
Apr 28, 2019 07:45 AM
Linson
Sep 21, 2015 01:08 PM
Stryker412
Sep 7, 2015 09:11 AM
84 TA NV
Sep 6, 2015 08:02 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
