Headlights and Parking lights
Old Jan 12, 2013 | 12:23 PM
19GTA92's Avatar
Car: 1992 Pontiac Trans Am GTA
Transmission: 5 speed
Whenever I push the parking light button, my headlights flip up. I don't know if that is how they are supposed to be, but I was wanting to know if there was a way that I could make it so I can push the button and they would not flip up?
Old Jan 12, 2013 | 12:29 PM
tzim350HO's Avatar
Car: 1991 Trans Am GTA
Engine: 350 carbed
Axle/Gears: 7.5 10 bolt 4.10
Re: Headlights and Parking lights
Thats the way they are suppose to work. My 91 is the same way. the only way i know to keep them from popping up is disconnecting the headlight motors which is pretty easy but just inconvienient when it comes dark and needing headlights
Old Jan 12, 2013 | 12:55 PM
19GTA92's Avatar
And I was thinking about maybe cutting that wire, but thats the only wire that will make the head lights pop up so that won't work either. I don't know, but it looks a lot better when I'm driving and the headlights are not up. I've gotten it some how a couple times to not pop up but I think that was just luck.
Old Jan 14, 2013 | 04:36 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Slam The Door
Replace the switch OR you can install a relay in the headlight portion of the Headlight Switch circuit so the relay controls the doors, so the result will be the doors will open only when the headlights are on.
Happy Racing!
I Hit The Water Barrels Because My Car Was Dirty
Old Jan 19, 2013 | 08:19 PM
theBIRD2445's Avatar
Car: 1991 Firebird Formula
Axle/Gears: 2:73
i dont know the solution but, the headlights shouldn't come up with the parking lights. mine dont
Old Apr 8, 2021 | 11:54 AM
aab142's Avatar
when my OEM factory switch died, i replaced it with an autozone (i need headlights now) and it pops up the headlights when the parking lights are turned on. (frustrating) I'm going to order a factory replacement
luvofjah
Sep 27, 2016 10:29 AM
91BirdGTA
Oct 15, 2012 04:37 PM
cjames9001
Jan 17, 2012 05:33 PM
Boreen
Sep 7, 2011 03:58 PM
Reyman
Jun 14, 2010 08:51 AM
