84 voltage regulator wiring issue
Old Jan 16, 2013 | 05:01 PM
jkrueg43's Avatar
Car: 1984 Chevy Camaro Berlinetta
Engine: 5.0 4bl carb
Transmission: automatic
ok so my 84 berlinetta has an issue charging the battery, i've recently replaced the alternator and belt as well as the positive and negative cables and a new battery. so i took it to a mechanic because this extended far beyond my scope of expertise, the mechanic told me they needed to check the wires coming from the voltage regulator. so $300 later the guy tells me that they had to cut some wires to connect to the hot wire from the voltage regulator and replace it. so after a month the car is doing the same thing, not charging the battery. the guys shop is closed down and on top of that my radio didnt work after i got it back, i take my car to another shop to get it checked out and they told me the guy cut the wrong wire and and the hot wire isnt getting any power to it. so does anyone have any layman wiring diagrams so i can figure out which is the correct wire to connect so the voltage regulator will work and perhaps get my radio fixed as well? i would greatly appreciate any help or responses, this car is my daily driver and i need her working! thanks.
Old Jan 16, 2013 | 06:23 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: 84 voltage regulator wiring issue
Here is a wiring diagram for the charging system for your car. Hope this helps you out.
eightsixseven
Dec 16, 2024 01:50 PM
mdtoren
Aug 23, 2015 12:52 PM
Fronzizzle
Aug 17, 2015 02:52 PM
mdtoren
Aug 16, 2015 05:45 PM
