no cig lighter, hatch, horn, door locks
Old Jan 17, 2013 | 08:44 PM
hotrodln's Avatar
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
ok i've searched and seen lot of folks with this problem. my acc fuse is fine. i do beleive i have changed it before...always after my son borrowed the car and just HAD to plug something into the cig lighter. so i looked in it and it's a little crusty. The ACC fuse is still good. i even replaced it just to make sure i wasn't seeing things. the acc fuse socket has power. I saw one post where it was suggested that the ignition switch could cause this problem. there's no fusable link AFTER the fuse is there? a relay that could make all this go dead? wire harness connectors don't normally come apart on their own...so what you guys think?
Old Jan 17, 2013 | 09:07 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: no cig lighter, hatch, horn, door locks
Not sure on an 84, but on an 88, the fuse that protects all that is CTSY.
Old Jan 17, 2013 | 09:37 PM
hotrodln's Avatar
Engine: Lt1 in IROC
I checked and i don't have any fuses labled CTSY. all the rest of them in the fuse block are all ok.
Old Jan 17, 2013 | 09:52 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Which car in your sig are you working on? The 84 or 87?
Old Jan 17, 2013 | 09:55 PM
hotrodln's Avatar
Engine: Lt1 in IROC
its the 87.sorry if that wasn't clear...
Old Jan 17, 2013 | 10:52 PM
jermdm's Avatar
Car: 1989 Iroc-z
I looked at the diagrams and all the items are powered by the ACC fuse. 1 of the diagrams says courtesy but it should be the same fuse. Have you checked for power on both terminals of the fuse? Dont assume that the fuse is ok even though you already replaced it. If thats ok, I would start at the fuse box and trace the wire. Even check for a bad connection where the fuse plugs in. There are other items powered by this fuse as shown in the cig. lighter diagram. Check to see if those items are working if your car is equipped with them. The only thing I see thats common with all the items is the splice S203, but if everything isnt working, the open in the wire would be before the splice. The orange wire is going to be what you focus your concern on. I have included diagrams to help you out.
Attached Thumbnails no cig lighter, hatch, horn, door locks-41905753.gif   no cig lighter, hatch, horn, door locks-41898670.gif   no cig lighter, hatch, horn, door locks-41905724.gif
Old Jan 17, 2013 | 10:54 PM
jermdm's Avatar
Car: 1989 Iroc-z
Here is the other diagrams.
Attached Thumbnails no cig lighter, hatch, horn, door locks-41905569.gif   no cig lighter, hatch, horn, door locks-41905808.gif
Old Jan 18, 2013 | 07:32 AM
hotrodln's Avatar
Engine: Lt1 in IROC
hey thanks for the diagrams. i will check this out this weekend. I know i saw a "slice" into the orange wire when i was under there. i think the car used to have a security system long ago. i'll let you know what i find. thanks
Old Jan 20, 2013 | 05:23 PM
hotrodln's Avatar
Engine: Lt1 in IROC
well i thought i was onto something when i located the orange wire and found that somebody had used one of those plastic " pincher" connectors to hook something else up to it....maybe a CB radio or something- there were some small holes in the dash from something that had been removed....so anyway i took the connector off and the orange wire was fine and had power. of course i don't know if this orange wire was coming FROM the fuseblock or GOING to it.....gotta look at it some more.
Old Jan 27, 2013 | 09:14 PM
hotrodln's Avatar
Engine: Lt1 in IROC
Ok i did a little more digging this weekend. Going from the wire diagrams. i followed the bigger orange wire to a Junction block on the drivers side kick panel. There is power at the larger orange wire going into this block, but NONE of the smaller orange wires have power- with the key on or off. Does anybody know if this means my ignition switch is part of the problem? or what it might be? thanks
Old Jan 30, 2013 | 08:11 AM
Eric Witt's Avatar
Its a fuse happens to me all the time, i have a 87 and its the ACC fuse 30amp
Old Jan 30, 2013 | 08:42 AM
hotrodln's Avatar
Engine: Lt1 in IROC
that's the problem- the ACC fuse is fine..........
Old Apr 15, 2013 | 07:51 PM
hotrodln's Avatar
Engine: Lt1 in IROC
ok here's an update....after lots of digging and checking, i found that the ACC fuse socket had a slight amount of corrosion on it that kept the current from flowing. so even though the fuse was good, it wasn't making good contact. So thanks to everybody who tried to help me with this- most of you were right! it was the fuse!
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
billybob6110
Sep 23, 2015 01:30 PM
SG91camaro
Sep 5, 2015 10:27 PM
