Reasons to Disconnect IAT?!
Old Jan 19, 2013 | 05:51 PM
BlackTopKing's Avatar
Car: 1987 Trans Am GTA
Axle/Gears: Posi 3:42
Finally getting into the 87GTA this weekend that i recently got and found the IAT to be disconnected.
L98 w/T56 swap
Of course I am getting a code for it (23) but am kinda confused why it would be disconnected?
So before i pluged it in or did a relocation mod (most likely bad) i figure i ask.
Any thoughts
thanks in advance
Old Jan 19, 2013 | 06:03 PM
tzim350HO's Avatar
Car: 1991 Trans Am GTA
Engine: 350 carbed
Axle/Gears: 7.5 10 bolt 4.10
Re: Reasons to Disconnect IAT?!
It should be plugged in. It tells the computer the air temp reading so it can make fuel adjustments depending on the temperature.
Old Jan 19, 2013 | 06:51 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
relocation mod, it will eat a ton of fuel that way.
Old Jan 19, 2013 | 10:06 PM
The relocation mod would cause it to eat more gas?
relocation to intake (piping vers manifold)?
And yeah I agree it should be plugged in, just so odd to be unplugged Iwould think it was intentional, so Im trying to figure out, why? LOL
Either way, i am def running rich so I will plug it in tomorrow and see how it effects things.
Iam going to expect its bad though, meaning sensor.
Old Jan 19, 2013 | 10:59 PM
ninetyone's Avatar
Axle/Gears: 3:42
yes, it will tell the ecm that the air temp is colder than it actually is in the plenum. It is not easy to plug back in. You will have to use two hands. One hand from behind the plenum to grab the harness plug with and line it up under the IAT sensor, and the left hand you will need to use a flat head screwdriver between the runners ,then place the screwdriver on the bottom of the harness plug and push up. Unless you want to remove the runners. That is just a PIA.
Old Jan 21, 2013 | 08:00 PM
Yeah i am not looking forward to it, especially if it does not do any good. I will try this tomorrow and see if it runs any better
Old Jan 21, 2013 | 09:36 PM
one92rs's Avatar
Car: SOLD!!!!!
when I installed my aftermarket air cleaner I installed mine in the bottom of it toward the rear. all I did was measure the factory hole and drilled the same size in the aftermarket one and installed the sensor and the clip in it. works fine.
Old Jan 22, 2013 | 03:10 PM
Yeah I am going to do the same. I just think its so odd that either someone forgot to put it in (connect it) or they disconnected it for some odd reason...
Cause even if it was bad...disconnected would casue same error...why go threw trouble to disconnect...
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
gord327
Oct 3, 2015 01:25 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
FueledSoul
Sep 29, 2015 08:58 PM
