Cruise Control switch bad?
Old Jan 24, 2013 | 02:39 PM
19GTA92's Avatar
Car: 1992 Pontiac Trans Am GTA
Transmission: 5 speed
I found where the vacuum lines go for the cruise control and hooked up the cable to the throttle. But the cruise still won't work. Is there anyway to test to see if the switch is bad?
Old Jan 28, 2013 | 04:35 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Cruisment Amusement
Using a voltmeter or test light (the type for testing for voltage, not a continuity tester) probe the gray wire at the Cruise Module located behind the right side of the dash IP.
When you switch the Cruise to ON, is there power there?
Then probe the
gray wire with a black stripe.
The Cruise Module is located behind the right side of the dash IP.
Happy Racing!
If We Don’t Get Cawt We Ain’t Cheatin
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Street Lethal
Aug 13, 2015 08:28 PM
stalkier
Aug 13, 2015 12:59 PM
Bull86
Aug 10, 2015 05:43 PM
