IAC valve: what do I do to test the circuit?
Old Jan 29, 2013 | 08:19 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
I developed an erratic idle and hard start, so I replaced my IAC valve. The car seems to start better and the idle isn't all over the place, but it seems to jump up to 1500 pretty quick and wants to stay there. I have checked but can not seem to find any vacuum leaks...
I have heard I need to set the Minimum Air, but why would I need to do that if I never tinkered with it in the first place? Perhaps my electrical connection is at fault? How do I test the pigtail?
Old Jan 29, 2013 | 08:23 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: IAC valve: what do I do to test the circuit?
You can check it with a iac noid, sounds like the iac is sticking or the motor is shot.
Old Jan 29, 2013 | 08:26 PM
carattini's Avatar
Car: Pontiac 89 GTA
Engine: 350 TPI 5.7L V8
Is your dip stick tube in the hole?
I have a 89 GTA and the tube felt of And since then my car will Idle very hi
Old Jan 29, 2013 | 08:49 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
My dipstick is there(!)and the IAC motor is new.
Old Jan 29, 2013 | 08:51 PM
Engine: Lb9
Transmission: M20
Have you checked for vacuum leaks ?
Old Jan 29, 2013 | 09:10 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
See above...
Old Jan 29, 2013 | 09:26 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
That was weird- I checked my dipstick again and it was loose. Put it back in place and the think wouldn't idle at all without me giving it gas. Drove it for a while and the idle climbed back up to 1500 again. Started it again and it idled beautifully for a minute then back up to 1500!
Old Aug 23, 2013 | 05:13 AM
DRIVE2FAST's Avatar
Car: 90 IROC 5.7 1LE CLONE 89 GTA 88IROC
Engine: 5.7TPI / 5.7TPI/ 5.7TPI/ 4.3 CMFI
Transmission: 700R4 UPGRADED 700R4STOCK700R4STOCK
Axle/Gears: 3.23 10 BOLT 3.27 9 BOLT 2.77 9BOLT
1500 IS WHERE THE ENG IDLES WHEN THE IAC IS AT FULL OPEN ( 160 COUNTS)
OR ITS GETTING EXTRA AIR FROM SOMEWHERE ?
MY PROBLEM IS THE ENG FIRES AND DIES IMMEDIATELY AFTER START. IT WILL IDLE IF I OPEN THE THROTTLE PLATE SLIGHTLY. I SUSPECT THE IAC IS STICKING CLOSD. ILL POST MORE WHEN I RUN MORE TEST / CLEAN IT ETC...
gta892000
Aug 11, 2019 11:16 AM
86IROC112
Nov 27, 2015 09:54 AM
gta892000
Sep 16, 2015 12:37 AM
greenyone
Sep 8, 2015 08:41 PM
greenyone
Sep 2, 2015 03:39 PM
