Is this my vats?
Old Mar 1, 2013 | 02:02 PM
Kennycarlone's Avatar
Car: 91 RS T-Top
Engine: 305 High output TBI
Transmission: automatic 40LB...
Axle/Gears: Ten bolt
Is this my vats?
Old Mar 4, 2013 | 02:28 PM
Zane M's Avatar
Car: 1991 GTA
Engine: LB9
Re: Is this my vats?
Couldn't tell you...your video is private.
Old Mar 4, 2013 | 02:35 PM
RockShowTrader's Avatar
Car: 1988 GTA
holy **** his vats disabled his youtube video.
Old Mar 4, 2013 | 02:40 PM
Phenom-1's Avatar
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
Old Mar 4, 2013 | 03:05 PM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Nice!
Old Mar 4, 2013 | 04:17 PM
Zane M's Avatar
Car: 1991 GTA
Engine: LB9
Old Mar 5, 2013 | 01:11 AM
Car: 91 RS T-Top
haha, sorry ive never used youtube to upload before... it should work now.
Old Mar 5, 2013 | 02:38 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Doesn't even your SES light go on? Does your fuel pump start to whirr when you first turn the key to the ignition position? Why isn't there even any sound from the beeper (have you ripped it out)?
Old Mar 5, 2013 | 07:28 PM
Ashton89iroc's Avatar
Car: 1987 IROC-Z
Engine: Vortec 350 crate #12530282
Transmission: 700-r4 Auto
from my experience, i would say it is indeed your vats. I have mine wired up to act as a sort of cutoff switch. On my IROC, the previous owner swapped out the steering column for one with a normal key in it while still keeping the vats wired up and the key in at all times, i simply extended that to my center console and now i can remove that key and even if someone breaks in, they cant steal it. back to the point however, if i try and start the car without the vats key, this exact thing happens. I would assume you have a faulty wire somewhere and it is not allowing the key to complete the circuit.
Old Mar 5, 2013 | 09:29 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
NCC asked some very good questions. Maybe one more to add: does the security light flash a few times when you turn on the ignition?
Something does not click here (pun intended). You should be seeing more lights on the dash. A desperate grasp at a straw: check your ECM/FP fuse by the battery. It is in a single fuse holder, clipped to the fender. It looks more like a dead-end connector.
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
86White_T/A305
Sep 21, 2015 05:28 PM
Winchester1094
Sep 15, 2015 09:48 AM
