Electrical-No power from batt to car/system dead
Old Mar 10, 2013 | 09:06 PM
roysatikas's Avatar
Car: 91 RS
Engine: 4 bolt 350, .060 over
Transmission: 700R-4
Came back to drive home from store and car had No Power! No dome, under hood, head, brake, or under hood light. Checked the following: 12.5v at batt/connected jumper cables- still no lights or cranking, buzzer etc./12.5v into and out of distribution block, all grounds-cables + & - good/cleaned terminals and cables. checked all fuses in fuse block/ also checked power to fuse block and found NONE. 91RS running a carb 350 hei 700-R4 w/o computer control except for the speedo and TQ lock up. This car has been running for 10 years in this configuration. What am I missing, does power go to the computer before the fuse block? Is ther a "main" fuse or link prior to the fuse block? I have never seen this before and any help would be greatly appreciated.
Thanks to all.
Roy
Old Mar 10, 2013 | 09:12 PM
tomlyons's Avatar
Car: 92 camaro rs
Engine: 3.1
Axle/Gears: rear disc non abs
Re: Electrical-No power from batt to car/system dead
Thanks to all.
Roy
there is a fuse under the pass side fender next to the air filter may look good but may need to be cleaned
Old Mar 10, 2013 | 09:49 PM
roysatikas's Avatar
Car: 91 RS
Thanks Tom, how do I access this fuse under the fender? remove inside wheel well cover ?
Old Mar 10, 2013 | 09:57 PM
roysatikas's Avatar
Car: 91 RS
OK just thought about it more, area behind the pax head lights inside the fender? I swapped out the original TBI V-6 10 years ago and put my battery in that location. What does the fuse look like?
Roy
Old Mar 11, 2013 | 10:14 AM
roysatikas's Avatar
Car: 91 RS
No sweat, found the fuse/20amp it is clean and I am getting power to the connection. The orange wire goes "out" from the fuse connection to the computer I am guessing so I will ck for continuity or any additional fuses to the computer. Anybody else have any Ideas?
Thanks,
Roy
Old Mar 11, 2013 | 01:02 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Everything gone dead sounds like a fried fusible link.
Old Mar 12, 2013 | 03:46 PM
roysatikas's Avatar
Car: 91 RS
Checked the fusable links off the distribution block and there is 12.5 volts downstream of the two links connected. I also have 12.5v after the fuse located in/on the pax forward front fender. I'm guessing this may power the ECM/computer. Does anyone know if the ECM is dead should you have power to the head or any other lights, as they should be hot at all times. It is hard to tell with the schematics in the Haynes manual with each system diagramed individually. Tomorrow I'll keep trying but someone must have seen this before.
Thanks,
Roy
Old Mar 15, 2013 | 10:12 AM
spray004's Avatar
Car: 1991 Camaro RS
Engine: 355
Transmission: BTO 700R4
Axle/Gears: 4th gen 3.73
Bad VAT? I had my VAT bypassed with a piece of wire. If the wire was missing,nothing would work.
Old Mar 20, 2013 | 12:20 PM
roysatikas's Avatar
Car: 91 RS
Thanks to all who replied. I solved the problem, note to all: bad connector at starter post supplying HOT into fuse box etc. There are 3 wires that have fusable links that connect to the starter post which the positive battery cable is also connected that supply Hot to the car ie: head,dome,underhood lights, fuse panel etc. I had no continuity touching the connector end and the wires downstream of the connector which could have been a fusable link failure but all three links would have failed, in this case after cutting off the connector, tying the 3 wire ends together, jumping power from the batt to the wires everything had power and worked. Really strange, could not pull connector off, but I had used a AWG auto wire connector @ 8 years ago with 3 fusable link wires tied to it, melted the plastic protector on it to seal it and I think the plastic somehow interfeared with the fusable link wire connectivity after a long period of time (8 years) Spring is here get your hot rods running and thanks to all. Roy
BRoss99
Aug 10, 2025 05:08 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
lt1z350
Aug 28, 2015 05:57 AM
sailtexas186548
Aug 24, 2015 10:11 PM
Bradsaundry
Aug 12, 2015 12:34 AM
