SOMEONE HELP I DONT HAVE BREAK LIGHTS!!!
Old Mar 24, 2013 | 05:50 PM
mack1985transam's Avatar
Car: 1985 trans am
Engine: 355 vortec built 4 bolt main
Transmission: 700r4 w/ shift kit b&m console mega
Axle/Gears: 3.08
Okay so on my 1985 trans am I had a brake light go out. One week later they all stop working. My hazardous lights work and turn signals works. But when I press the break pedal they don't come on at all. I replaced my break switch, replaced all double and single filament bulbs correctly, & checked/replaced all fuzes!!! I don't know where to go now. This is a stumpier!!!!
Old Mar 24, 2013 | 10:10 PM
Car: 1985 trans am
Axle/Gears: 3.08
Re: SOMEONE HELP I DONT HAVE BREAK LIGHTS!!!
Any help would be appreciated I know someobe has some good leads this site had never done me wrong!!!
Old Mar 25, 2013 | 06:33 AM
Got power on both sides of the brake light switch when you press the pedal?
If you do, it's probably the turn signal switch in the column, right below the steering wheel.
Old Mar 25, 2013 | 07:38 AM
Car: 1985 trans am
Axle/Gears: 3.08
No I don't have break lights period
Old Mar 25, 2013 | 09:21 AM
Car: 1985 trans am
Axle/Gears: 3.08
All bulbs have been changed and are perfect! All fuzes appear to be perfect! All turnsignals work beautifully! Hazardous lights work fine! But no break lights period!
Old Mar 27, 2013 | 02:55 AM
JDud's Avatar
I'm struggling with my lights right now too....will let you know if I find a solution.
Old Mar 27, 2013 | 07:31 AM
usc iroc's Avatar
Car: 89 Iroc
Engine: 383
Transmission: 700
Axle/Gears: 4.11
Is the switch behind the brake pedal engaging fully? Sometimes they need a little adjustment.
Old Mar 27, 2013 | 10:32 AM
Beef's Avatar
Car: 89 RS
Engine: Stock L03
Transmission: Stock T5
Axle/Gears: Stock, Too high
That's not an answer to the question.
Get a testlight, changing parts without knowing where you have power is pointless.
Do you have power going into the brakelight switch? Do you have power coming out of the brakelight switch?
On vehicles that have bulbs performing multiple functions stop/turn/tail, as I believe T/As do, the power for stop and turn both will go thru the turn signal switch, just because one function of the switch works does not mean all do. If your turns and hazards work you may assume the chassis wiring is not the culprit.
Old Mar 27, 2013 | 10:43 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Reverse lights working?
jaridjohn
Jul 8, 2024 03:49 PM
ktthecarguy
Jul 5, 2020 11:46 AM
hokis
Wheels and Tires
Aug 26, 2015 04:21 PM
89fast5oh
Aug 24, 2015 08:14 AM
Omega
Aug 10, 2015 12:46 PM
