can somebody please help with break light!????
Old Mar 25, 2013 | 12:53 PM
mack1985transam's Avatar
Car: 1985 trans am
Engine: 355 vortec built 4 bolt main
Transmission: 700r4 w/ shift kit b&m console mega
Axle/Gears: 3.08
Okay so here's the skinny.... I have a 1985 trans am every bulb Burns beautifully and all are new. All fuzes have been checked multiple times. I replaced the break switch. Rebuilt the steering column about 3 months ago and everything work fine. My turn signals work all the way around along with hazardous lights. Reverse lights work too. When I apply the break pedal I get no break lights. My running lights work too. What could be the problem. If its grounds I have cleaned and check the two in the trunck area and don't know of any more PLEASE HELP ANY WOULD BE APPRECIATED.
Old Mar 26, 2013 | 06:51 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: can somebody please help with break light!????
Pull the underdash panel and the kick panel next to it. You need to check the white wire at the brake switch. Use either a DMM or test light, and you should either get a light or battery voltage. Next, probe the turn signal switch at position P, which is the other end of the white wire. You should then probe the yellow and dark green wires coming out of the turn switch.
The system is weird in that the turn switch is used to turn the brake light on the side that the signal is activated OFF so that the signal can function.
Old Mar 26, 2013 | 08:12 PM
Car: 1985 trans am
Axle/Gears: 3.08
Maverick your response was great could you just please clearfy just a little more on what all to probe? Sorry its just that's its a little hard to understand when its in words...
Old Mar 26, 2013 | 08:44 PM
Car: 1985 trans am
Axle/Gears: 3.08
Maverick can you please clarify a little its hard to understand in writting sorry I think I understand mist of it....
Old Mar 26, 2013 | 08:52 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Both wires at the brake switch, the orange wire going in and the white going out
The other end of the white wire at the turn signal switch, position P
Yellow and Dark Green wires coming out of the turn switch
Orange wire is hot full time (or should be)
White wire and yellow/green wires SHOULD have power with the brake switch closed (either pulled out of the brake pedal assembly or pedal depressed)
Old Mar 26, 2013 | 08:57 PM
90camaro355rs's Avatar
Car: 72 nova/ 90 camaro rs,04 suburban
Engine: blown 327/ 355/306/355/5.3
Transmission: muncie 4 speed/T5/powerglide,4l80e
Axle/Gears: 342/411/456/ moser axles
Why not check the adjustment on the brake switch you installed, It could be out of adjustment to far in so when the pedal is depressed it wont make the connection for the brake lights to come on, just a thought.
Old Mar 26, 2013 | 09:11 PM
Car: 1985 trans am
Axle/Gears: 3.08
90 camaro I did this multiple times...... maverick your the best man thanks a lot!!! So your saying if I'm not getting power in one of these wires then I have a bad connection by a cut wire or ect.
Old Mar 26, 2013 | 10:18 PM
Engine: 2.7L V6
Axle/Gears: 4.41
It's one of only a couple things:
1. You have no power to the brake switch (orange wire)
2. You have no power coming out of the brake switch (white wire)
3. You have no brake signal going into the turn signal switch (other end of white wire)
4. Your brake signal is being lost in the turn switch somehow and not going out on the yellow and green wires to the tail lights.
You already know the turn signals work.
You already know the hazards work and the brake switch SHOULD be getting power (STOP HAZ fuse). But that doesn't mean it is...
Both of these show that the bulbs are good and so is the tail light ground by the hatch latch.
So, basically, your issue is probably a cut wire somewhere between the STOP HAZ fuse and the turn signal switch. If the harness has been cut open, it could have gotten cut then OR the splice between the hazard flasher, brake switch, and fuse has come apart.
Old Mar 26, 2013 | 10:29 PM
Car: 1985 trans am
Axle/Gears: 3.08
Maverick you have been a great help.God bless you brother!!! One more q do you know where exact that factory splice between the hazard flashers, break switch, and fuze is at?
Old Mar 27, 2013 | 11:52 AM
Engine: 2.7L V6
Axle/Gears: 4.41
If the location didn't change between your 85 and my 87 FSM, the splice should be in the main harness roughly behind the speedometer. Just follow the orange wire from the brake switch into the main harness and it should be pretty close to where the brake switch wiring splits off.
jaridjohn
Jul 8, 2024 03:49 PM
ktthecarguy
Jul 5, 2020 11:46 AM
hokis
Wheels and Tires
Aug 26, 2015 04:21 PM
89fast5oh
Aug 24, 2015 08:14 AM
Omega
Aug 10, 2015 12:46 PM
