tried to measure voltage between fuse and ground, sparked
Old Mar 27, 2013 | 09:10 PM
FreeSpirit's Avatar
Car: 92 RS
Engine: 305 TBI
Why would it spark at the fuse? I turned the car on, tried to measure voltage between ground on the car near door and the fuse, and it sparked. Iwas just testing that way of testing fuses
Old Mar 29, 2013 | 09:15 AM
Ransford2987's Avatar
Car: 1990 IROC-Z/1980 Firebird
Engine: 5.7 TPI
Re: tried to measure voltage between fuse and ground, sparked
What are you using to measure voltage? If you're using a multimeter, there are usually different terminals for the leads for voltage and current. To measure current or amps, a mulitmeter usually has a fused closed circuit inside to measure up to a specific amount (10 or 20 maybe, depending on the quality of the meter?). Make sure your leads are in the correct voltage reading terminals and try again. You don't need a closed circuit to measure a voltage potential, so you shouldn't get a spark.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
billybob6110
Sep 23, 2015 01:30 PM
Gunsbee
Sep 7, 2015 07:10 PM
90formulaVortec
Sep 3, 2015 09:26 AM
RyanJB
Sep 2, 2015 01:27 PM
