Dash lights on a Berlinetta
Old Mar 31, 2013 | 03:06 AM
Mattandbec1's Avatar
Hi all.
We have a 1984 Berlinetta, with the electronic dash.
The prob we have is, dashboard lights, guages etc work well, but as soon as you turn to headlights on, all lights and display numbers (speedo) go off.
If you turn the headlights off, all speedo/tacho lights come back on.
This does make it rather difficult when driving at night.
Any help or answers would be sooo awesome.
And yes, we are Aussies, so if anyone else is from down under and has a Berlinetta, we would love to hear from you.
Regards
Matt and Bec
Old Apr 1, 2013 | 04:30 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
The Next Dim Mention
Using a voltmeter or test light (the type for testing for voltage, not a continuity tester) probe the dark green wire with the White stripe going to the dimmer wheel.
When you rotate the wheel back and forth — what happens on the meter or test light?
Then probe the
brown wire.
Then probe the probe the plain
dark green wire.
Happy Racing!
He Must Have Been Be Cheating - Because I Was And He Almost Beat Me.
Old Apr 11, 2013 | 05:47 AM
Re: Dash lights on a Berlinetta
Nina..... Thanks heaps for your info.
Gave me a starting point.
Found that the dimmer wheel was faulty and causing a short.
As trying to locate a dimmer wheel in Oz would be like finding hens with teeth, I removed to wires to the dimmer wheel and terminated the together.
This now allows the dash to work with lights on, even slightly dimming when turning them on.
Thank you again for your info.
Cheers
Matt
Pilotrick50
Sep 2, 2015 12:48 PM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
