No power
Car: 83 Z28, 84 Z28
Engine: 305 crossfire, 350 carberator
Transmission: 700r4, t56
Axle/Gears: 10 bolt 3.42, 9 bolt 3.73
No power
I have no power to the fuse block, ground cable is good. Ive got 12+ volts to the alternator and past the fusible link. Now I'm stuck nothing works, all the fuses are still good.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
No Power This Hour
There are several Fusible Links, therefore even tho the one you looked at was good, others might be bad.
Some are located at the starter, others are near the battery.
Location and amount varies by model year but you failed to post you that info so we’ll leave you with the above generic.
Happy Racing!
After The Fourth Barrel Roll I Lost Control Of The Car
Happy Racing!
Car: 83 Z28, 84 Z28
Re: No Power This Hour
Happy Racing!
Happy Racing!
