automatic to T5 swap wiring help needed
Old Apr 8, 2013 | 08:12 PM
ld91's Avatar
I have a 91 Z28 with a 305 tpi, auto tranny. I am wanting to install a T5 from a donor car (92 RS 305 tbi). The plug for the automatic is a 4 prong and the standard has 2 prongs in the back for the speedometer and 2 on the side. What wiring modifications and/or ECM will I have to make without having to butcher the harness ?
Thanks in advance.
Old Apr 9, 2013 | 03:50 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: automatic to T5 swap wiring help needed
Originally Posted by ld91
What wiring modifications and/or ECM will I have to make ?
Ultimately your should have a manual tune for your ECM
You don't use the wiring from the auto plug ( is for the TCC )
You need to extend the back up switch wiring from the 6 wire switch at base of the auto shifter through the floor down to the reverse switch on the T5 ,
The P/N wiring from the shifter switch needs extending to the neutral safety switch on the clutch pedal.
The 2 remaining wires at the switch (org and blk ) get taped up and made safe
Old Apr 9, 2013 | 06:09 AM
ld91's Avatar
Thanks for the response. Sounds fairly simple.
So to be clear, I don't need or have to use the 4 prong plug. I just need to use the wiring from the neutral switch to the clutch petal?
Old Apr 9, 2013 | 03:47 PM
ld91's Avatar
I read your reply when I was half asleep. You answered everything I asked about so please disregard that last post. Thanks for the help.
Old Apr 14, 2013 | 07:49 PM
Nolan6121's Avatar
Car: 87 Pontiac Trans Am
Engine: 5.7 357v8
Transmission: t-5
Axle/Gears: Stock
Elephantismo
Feb 13, 2019 12:51 AM
beltran89
Theoretical and Street Racing
46
Oct 7, 2015 07:36 PM
loud91rs
Oct 5, 2015 10:05 PM
bjpotter
Oct 4, 2015 07:48 PM
aharvel50
Sep 21, 2015 07:31 PM
