Starter Enable Relay
Old Apr 8, 2013 | 09:37 PM
CHCKLS's Avatar
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
Just a quick question...I've got an 89 where the wiring diagrams show a "starter enable relay".
Is this only for the VATS circuit? As in if I ditch the VATS do I still need the relay? Diagram is a little confusing to me on this one particular item.
Thanks!
Old Apr 8, 2013 | 10:01 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Starter Enable Relay
The relay can be deleted at any time because even it you kept VATS active,
it would still disable the injectors to prevent the engine being started without the correct key
One less item to fail on a aging car
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
thunder57
Nov 7, 2015 02:28 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
