Power widows just stopped....
Old Nov 5, 2012 | 07:54 PM
Joshua Dunn's Avatar
Okay so its a nice warm day in florida, I am in the middle of moving to a new home. I start rolling down my windows to get some nice cool air circulating in the car and halfway down they stop dead. No longer able to go up or down....
Okay so here is some more info.
For starters nothing has been touched in the last few months this problem is totally random and out of the blue...
I have an alarm system wired to my car. It has been in for almost 3 years now never gave a problem but here is where stuff gets weird. When I hit my power window button the door locks, the alarm led will stay lit until i let go and the alarm chirps.... How this is happening is beyond me seeing as how my alarm is not tied to my windows in the least bit.
I unplugged the alarm and tried it but nothing happened, this time no door click or alarm chirp of course. It is just strange and I have no clue what to do. My car is sitting there with windows halfway down because the garage is full of boxes... If anyone has a clue or a quick fix please let me know!
Already tried:
Replaced the 30amp fuses under dash.
Old Nov 6, 2012 | 03:01 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
Re: Power widows just stopped....
the same thing happened to my passenger window. i have no clue why either and it has a brand new motor. When i push the down button the lights dim but the window doesnt move
Old Nov 8, 2012 | 12:29 AM
WyoJames's Avatar
Car: 1987 IROC
Engine: 305 TPI swapped to Holly 4bbl
Transmission: WC T5
My money would be on the window motor. And if you replace the window motor, make sure to replace the regulator too because if the regulator is crap, it can fry a brand new motor very quickly (learned that one the hard way on my pickup)
Old Nov 8, 2012 | 08:50 AM
IROCtheRoad's Avatar
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
Another thing to check would be the electrical connector on the motor. They usually have junk in them. I would clean it out and see if that helps.
Another thing to look into is running a standalone electrical system for the windows (Painless makes a kit). Everything I've read on them says they are much more efficient than the factory setup.
Old Nov 8, 2012 | 12:02 PM
Car: 1984 T/A
Engine: LQ4
Painless is a member? or a company?
Old Nov 8, 2012 | 12:16 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Since both windows stopped working instantly and at the same time, it is very unlikely that your motors went bad simultaneously and suddenly.
So before you go replacing window motors and doing a lot of unnecessary work, test that you have power at the window circuit breaker in the fuse box. It is not a standard blade fuse, it is a small metal box serving as a breaker.
If you have power on both sides of the breaker (with ignition on), check if it's still there with the window buttons pressed. Check both sides of the circuit breaker, that's important.
Let us know what you find.
Lou
Old Nov 8, 2012 | 05:07 PM
WyoJames's Avatar
Car: 1987 IROC
Transmission: WC T5
Whoops, misread and thought it was just one window that crapped out
Old Apr 3, 2013 | 05:25 AM
greekknight's Avatar
Any updates? I have the same problem. How I test the circuit breaker?
Old Apr 8, 2013 | 04:17 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Break Time
You can test the breaker by turning the key to the RUN position, then use a voltmeter or test light (the type for testing for voltage, not a continuity tester) to probe the
12 AWG pink wire coming out of the Fuse Block, while pressing one of the Window Switches.
Was power there when you did that?
Happy Racing!
After The Fourth Barrel Roll I Lost Control Of The Car
Old Apr 9, 2013 | 01:15 AM
Thank you for your help, I will try it!
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
