how to change turn signal bulb on 91 GTA?
Old May 9, 2013 | 03:47 PM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
How do I change the front turn signal bulb in the bumper on my 1991 GTA? It doesnt seem like I can reach around behind the bumper to twist it out.
Thanks!
Bill
Old May 9, 2013 | 08:03 PM
wgripp's Avatar
Re: how to change turn signal bulb on 91 GTA?
figured it out. 2 torx bolts on the front of each turn signal housing in the front bumper.
remove the 2 bolts, pull the housing forward.
twist the connector on the wiring harness to remove it from the housing.
twist the bulb to remove it.
twist new bulb in.
twist connector back into housing
screw 2 torx bolts back in to reinstall housing
Caspar
Jun 19, 2016 11:19 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
