What are these relays for? (pic)
Old May 15, 2013 | 02:19 PM
Sidethumper's Avatar
Car: 87 Pontiac Trans Am
Engine: Lapouttre Racing 350
Transmission: Rebuilt 700r4 Mild shift kit
Axle/Gears: 10 bolt 3.23 posi w/disc brakes
OK there is a set of relays right above the fuse cluster on the drivers side that was hooked up through the ECM witch I have deleted. What are these for ???
Old May 15, 2013 | 02:59 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: What are these relays for? (pic)
Esc module, fuel pump and fan relay and map sensor.
Old May 15, 2013 | 03:55 PM
If I Don't have the computer in the car anymore I wont need these correct?
Old May 15, 2013 | 04:00 PM
Engine: Lb9
Transmission: M20
You don't need them all but you might consider using the same mounting point for a bracket to mount the fan relay and if you are using a electric fuel pump mount it there as well but atleast upgrade to the newer style weather pack connecters and relays .
Old May 28, 2013 | 11:13 PM
The only plug I have left over there is the one that goes to the white box in that cluster. Did you read them from left to right or right to left lol. I need the fan relay as that is what I am trying to get running. Im not familiar with the newer style weather pack connectors and relays you are referring to. Im going to have to research them
BumpaD82
Feb 26, 2016 02:57 PM
Johnoooooo
Sep 22, 2015 08:55 AM
Gunsbee
Sep 7, 2015 07:10 PM
Glowsock
Sep 6, 2015 06:40 AM
