help with dash lights when brake pedal is pushed
Old May 20, 2013 | 10:07 PM
loujon's Avatar
the ignition and light switch is off but my dash/gauge cluster lights come on when I engage the brake pedal anyone know what is the problem? please help. 1983 Camaro z28 crossfire injection/tbi
Old May 21, 2013 | 09:59 PM
Stallion's Avatar
Re: help with dash lights when brake pedal is pushed
which lights come on the gauges? And does it happen every time you press the brake pedal?
Old May 22, 2013 | 03:54 PM
loujon's Avatar
thank you very much for trying to help. I found the problem. I had the wrog type bulb in the brake light circuit. had 1156 bulb in socket and it calls for 1157.
Old May 26, 2013 | 09:59 PM
Stallion's Avatar
Way to go. You found it! Your welcome. I had that same problem you did before. The rear is very picky with 1157 and 1156.
Old Feb 23, 2014 | 07:39 PM
gallaire's Avatar
Car: 91 trans am
Engine: ?
Transmission: auto 4sp
Axle/Gears: posi
all my lights come on when press brakes also 4 way flahers don't work where are the grounds located
Old Mar 3, 2014 | 04:56 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Dash 4 Cash
The black ground wires come out of the dash connectors and go to the ‘Convenience Center’ bracket.
The Convenience Center is located behind the knee bolster.
The Convenience Center contains a the Hazard flasher among other parts
(just to help you identify it),
and is to the right of the steering column.
Happy Racing!
If Your Communications Antenna Is Not Shaking At Idle, Your Cam Is Too Mild
1992 Trans Am
May 10, 2023 07:19 PM
redmaroz
Aug 16, 2015 11:40 PM
tnrednneck
Aug 13, 2015 08:57 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
apie2546
Aug 8, 2015 07:12 AM
