No VATS 89 IROC
Old May 24, 2013 | 08:30 PM
Stonehenge's Avatar
Car: 1989 5.7 IROC Dark Red/Blk 92Z28
Engine: 5.7
Transmission: 700R
No VATS 89 IROC
I recently bought an 89 IROC with 80,000 and noticed it doesn't have the VATS. My key has NO chip in it. Whats unusual is everything on my car works, a/c gauges, cruise etc. Is it possible that someone just removed it some time ago..? IIf so, how difficult is it to reinstall..? Any help would be appreciated.. Stone
Old May 25, 2013 | 12:15 AM
88gtatony's Avatar
Car: 1988 gta, 1986 trans an
Engine: 305 tpi, 305 tpi
Transmission: 5 speed, auto
Axle/Gears: 3.45, 2.77
Re: No VATS 89 IROC
its most likely they bypassed the system with the resistor trick, and therefore you dont need the chipped keys.
i know my 88 gta is like that, i found out the other day when it wouldn't start, under the dash i found the resistor, someone had soldered it in the wiring that went up to the ignition cylinder and it had come apart. re soldered it and the car starts fine now.
if they did the resistor trick, you could find out what ohms the resistor is.. and get a set of keys made and take the resistor out. and the vats system should work again.
thats my 02. cents, im sure others will chime in.
Street Lethal
Apr 30, 2019 12:14 PM
stalkier
Dec 6, 2015 11:25 PM
stalkier
Aug 13, 2015 12:59 PM
mustangman65_79
Aug 11, 2015 03:17 PM
djmarch
Aug 9, 2015 05:27 PM
