Digital Dash Shift Light
Old Jun 14, 2013 | 01:40 PM
fatalicshock's Avatar
Car: 87 Trans Am
So i have a 87 T/A with the digital dash and it was an automatic car converted it to 5 speed, now in the middle of going to a 6 speed and i would like to get the shift light to work dose anybody have any knowledge on this or know how to get this working it you be much appreciated.
~Steve
Old Jun 14, 2013 | 04:48 PM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
Re: Digital Dash Shift Light
Are you still running the chip from an auto? I know you can play with the rpm you want it to come on in a bin from a stick car. I will have to check my wiring diagrams to see if there is a difference between the two as well.
Old Jun 14, 2013 | 05:47 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
A7 of the ecm for a automatic controls tcc, in a enabled .bin will send power out for the shift light.
Old Jun 21, 2013 | 05:34 AM
Car: 87 Trans Am
i pretty sure i still have the auto chip in my car. Sorry i dont know what the bin is electronics arnt really my thing lol
Old Jun 26, 2013 | 07:50 AM
Car: 87 Trans Am
bump
Old Jun 26, 2013 | 07:56 AM
Engine: Lb9
Transmission: M20
The .bin is the Binary program in your eprom . The memcal in your car has four letters called a broadcast code this is the identifier of what .bin you have. the eprom can be reprogramed to a manual .bin with shift light.
Prom ID 1985-1992 TPI equipped engines
1987 305 (5.0L) "F" body Camaro-Firebird-Trans Am
Prom BCC Prom Code Scan ID Trans Gear Ratio Emissions Body
HCL 4405 1471 Auto 2.73 Fed F
HCM 4411 1481 Auto 2.73 Fed F
HCN 4415 1491 Auto 3.23/3.27 Fed F
HCP 4419 1501 Auto 3.23/3.27 Fed F
HCR 6919 1511 Auto 2.73 Cal F
AANR 4469 2281 5 spd man 3.08 Fed F
AANS 4473 2291 5 spd man 3.08 Fed F
AANT 4477 2301 5 spd man 3.45 Fed F
AANW 4485 2321 5 spd man 3.08 Fed F
AANX 4489 2331 5 spd man 3.45 Fed F
ABUN 8517 7961 Auto 2.73 Fed F
ABUP 8523 7971 Auto 2.73 Fed F
ABUR 8527 7981 Auto 3.23/3.27 Fed, Exprt F
ABUS 8534 7991 Auto 3.23/3.27 Fed, Exprt F
ABUT 8562 8001 Auto 2.73 Cal F
ABUU 8566 8011 Auto 2.73 Cal F
ABUW 8572 8021 Auto 3.23 Cal F
ABUX 8576 8031 Auto 3.23/3.27 Cal F
ABUY 8582 8041 5 spd man 3.08 Fed F
ABUZ 8585 8051 5 spd man 3.08 Fed F
ABWA 8592 8061 5 spd man 3.45 Fed F
ABWB 8596 8071 5 spd man 3.08 Fed F
ABWC 8602 8081 5 spd man 3.08 Fed F
ABWD 8606 8091 5 spd man 3.45 Fed F
ABWF 8618 8101 5 spd man 3.08 Cal F
ABWH 8624 8111 5 spd man 3.08 Cal F
ABWJ 8628 8121 5 spd man 3.45 Cal F
ABWK 8634 8131 5 spd man 3.08 Cal F
ABWL 8638 8141 5 spd man 3.08 Cal F
ABWM 8643 8151 5 spd man 3.08 Cal F
ACXS 1088 0791 Auto 2.73 Fed F
ACXT 1099 0801 Auto 3.23/3.27 Fed F
ACXU 1104 0811 Auto 3.23/3.27 Fed F
ACXW 1108 0821 Auto 3.23 Cal F
ACXX 1113 0831 Auto 3.23/3.27 Cal F
ACXY 1117 0841 5 spd man 3.08 Fed F
ACXZ 1122 0851 5 spd man 3.45 Fed F
ACYA 1126 0861 5 spd man 3.45 Fed F
ACYB 1130 0871 5 spd man 3.08 Cal F
ACYC 1135 0881 5 spd man 3.08 Cal F
ACYD 1139 0891 5 spd man 3.45 Cal F
ACYF 0886 0901 5 spd man 3.45 Cal F
AFUD 5611 5401 5 spd man 3.45 Fed F
AFUF 5615 5411 5 spd man 3.45 Fed F
1987 350 (5.7L) "F" body Camaro-Firebird-Trans Am and "Y" body Corvette
HCY 9539 1571 4 spd man 3.07 Fed Y
HCZ 4423 1581 4 spd man 3.07 Fed Y
HDA 4427 1591 Auto 2.59 Fed Y
HDB 4431 1601 Auto 3.07 Japan Y
HDC 4435 1611 4 spd man 3.07 Fed Y
HDD 4439 1621 4 spd man 3.07 Fed Y
HDF 4443 1631 Auto 2.73/3.07 Fed Y
HDJ 4457 1651 Auto 3.07 Fed Y
HDK 4461 1661 4 spd man 3.07 Fed Y
ABTB 0315 7741 4 spd man 3.07 Fed, Can Y
ABTC 0321 7751 4 spd man 3.07 Fed Y
ABTD 0731 7761 Auto 2.59 Fed Y
ABTF 0735 7771 Auto 3.07 Fed, Can, Japan Y
ABTH 0336 7781 4 spd man 3.07 Fed Y
ABTJ 0326 7791 4 spd man 3.07 Fed, Can Y
ABTH 0739 7801 4 spd man 3.07 Fed Y
ABTL 0743 7811 Auto 3.07 Fed Y
ABTM 0331 7821 4 spd man 3.07 Fed, Euro Y
ABTP 4757 7841 4 spd man 3.07 Fed Y
ABTR 4763 7851 4 spd. man 3.07 Fed Y
ABTU 4802 7881 4 spd man 3.07 Fed Y
ABTW 4806 7891 4 spd. man 3.07 Fed Y
ABWN 8656 8161 Auto 3.27 Fed F
ABWT 8674 8201 Auto 3.27 Fed F
ABWW 8682 8221 Auto 2.77 Fed F
Old Jun 26, 2013 | 08:33 AM
Car: 87 Trans Am
lol honestly this is way over my head
Old Jun 28, 2013 | 09:42 AM
Engine: Lb9
Transmission: M20
That is a list of broadcast codes for 87. The broadcast code is the letters on the top of the eprom that identify the programing. If you are needing it changed send me a pm I can assist.
Old Jun 29, 2013 | 09:03 AM
Car: 87 Trans Am
alright ill take a look tonight or tomorrow thanks
Old Aug 28, 2013 | 11:11 AM
ramicio's Avatar
Car: '87 Flame Red/Carmine Red GTA
There's still gotta be something to wire to enable the light to come on. The TCC and shift light circuit are on the same ECU pin, yet it never comes on for an automatic. It's not just inserting a bulb like the analog folks can do.
The_Phoenix
Feb 4, 2016 07:10 AM
Pilotrick50
Sep 2, 2015 12:48 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
tnrednneck
Aug 13, 2015 08:57 AM
beachrodder
Aug 7, 2015 04:27 PM
