Electrical / wiring / lighting question
Old Jun 18, 2013 | 02:45 AM
GMCTIM's Avatar
Car: 1990 Camaro R.S Convertible.
Engine: 5.0
Transmission: auto
Axle/Gears: stock
1990 Camaro RS question: When I have the steering wheel in the normal driving position, the dimmer switch doesn't work.
If I put the wheel all the way up, the switch works fine.
Also, several times when I tried to switch between brights & dims, the headlights went out all together for a second, but came right back on.
What causes this & how do I fix it? It's not fun having to move the column every time I need to switch.
I might end up putting some small fog lights under the core support somewhere just to guarantee that I will have some lighting in case the headlights go out. Any recommendations on small / low profile lights? How about LED's? Thanks!
Old Jun 18, 2013 | 11:46 PM
GMCTIM's Avatar
Engine: 5.0
Transmission: auto
Axle/Gears: stock
Re: Dimmer switch question
Any info is appreciated.
Old Jun 19, 2013 | 02:17 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Electrical / wiring / lighting question
Would say you answered your own question
The switch is most likely out of adjustment ,a common problem with age
https://www.thirdgen.org/forums/elec...placement.html (post # 6 )
https://www.thirdgen.org/forums/post...681-post5.html
If you can't work that out do this
https://www.thirdgen.org/forums/elec...ch-repair.html
Old Jun 19, 2013 | 11:09 PM
GMCTIM's Avatar
Engine: 5.0
Transmission: auto
Axle/Gears: stock
.... Yeah... I figured it had something to do with the dimmer switch, I just didn't know what to look at first or if there was adjustment on it.
Thanks for the links!
BRoss99
Aug 10, 2025 05:08 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
Omega
Aug 10, 2015 12:46 PM
