Electric speedometer troubleshooting help needed!
Car: 1986 Trans Am
My 86 t/a has an electric speedo that is not working.
When I first put it on the road it worked for a day or 2. I went down a bumpy road and it stopped working. Once it a while if I hit a bump it starts working for a second or 2.
So far I have taken out the cluster and cleaned the contacts and tightened all the contact screws on the ribbon board. I also unplugged the connector on the speed sensor and cleaned that with contact cleaner and plugged it back in. Also checked the connection on the buffer module and that seems fine.
Looking for advice on tests and trouble shooting to narrow down my problem.
I know if could be many things and just looking for how to test the various components like the speed sensor, buffer module, and speedo head.
Thanks!
Thanks!
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Electric speedometer troubleshooting help needed!
Your car has been converted from a speedometer cable ?
Car: 1986 Trans Am
No, 86 T/A had factory electric speedo. First year to have them I believe.
Engine: Lb9
Transmission: M20
huh, never knew that. You might look for a fsm on ebay. If you have a scanner or USB to aldl you can view the signal to to the ecm if if from the buffer if this is fuel injected. The digital dash birds had a issue with the ip ribbon seperating.
Car: 1986 Trans Am
I have a used factory service manual on order from ebay.
It will probably take a week to get here so if anyone has a wiring schematic in the meantime I would really appreciate it!
