Where to buy a 7520 resistor...
Car: 1991 rs camaro
Im trying to bypass vats and I cant find the right resistor. key came in at 7520. radio shack and all electronics stores don't have them here. is there a place online I can buy it? ive been googling it but I still cant find it.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Where to buy a 7520 resistor...
You won't
You have to solder individual resistors together to get the required value.
# 13 key you have will work with 7200 - 7820 ohm resistance so you should be able to get and use a single 7500 ohm resistor
Car: 1990 IROC
Check your resistance again. If it is 7500 ohms, get a 7.5k ohm resistor. Radio Shack should have them.
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
If RadioShaft doesn't have a specific resistor value (they don't carry a lot of values), you can always pay a lot of money for an online order through suppliers like Jameco, Digikey or Mouser. Let me check my box of resistors, maybe you get lucky and I have one in the range.
Bobby, do you live in Arlington, by any chance? :-D
Lou
Lou
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Over Complicating
As Bobby Hill said, it’s undoubtedly 7500 Ω.
Remember, resistors have tolerances, for example, a resistor labeled 7500 Ω, with a 5% tolerance, is allowed to be as high as 7875 Ω and as low as 7125 Ω.
Multimeters are not perfectly accurate.
If a multimeter has an accuracy of 1%, a perfectly made 7500 Ω resistor might read as high as 7575 Ω, or as low as 7425 Ω.
That’s why economy ANALOGUE meters are the fast way around the track.
Consumers get a hold of digital meters, the meter shows the device under test to be “off” an insignificant fraction of a fraction, and the consumer thinks there is something wrong.
Happy Racing!
Spin Me This Week . . . I’ll Spin You Next Week
Happy Racing!
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
If you would like to bypass the vats perminanly by having it programed out of the prom I can assist send me a pm.
Engine: TPI
DancesWithDeath, I found the right resistor. I just need your mailing address. PM me if still interested.
Lou
Lou
