ECM help needed
Old Jul 15, 2013 | 01:10 PM
stue's Avatar
ECM help needed
Hi guys,I'm trying to find out if a schematic diagram is available for my ECM,I have a 91 firebird 3.1 v6 vin code t,any suggestions or help would be greatly appreciated
Stuart
Old Jul 16, 2013 | 07:52 PM
Brads RS's Avatar
Re: ECM help needed
Stuart
Are you looking for a schematic of the internal workings of your ecm (7730) or the wires that are going to it (pin out)?
Old Jul 17, 2013 | 03:55 AM
stue's Avatar
Re: ECM help needed
Thanks for the reply,it's one for the internal workings I need,I have diagrams for the wires going to it
Old Jul 17, 2013 | 07:49 AM
Brads RS's Avatar
Re: ECM help needed
I cant seem to find the internal schematic (i had it at one time). What questions do you have or what do you need to know maybe i can help. I work with these computers every day.
Old Jul 17, 2013 | 07:58 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: ECM help needed
Old Jul 17, 2013 | 08:12 AM
stue's Avatar
Re: ECM help needed
Ok basically I've had a problem with long cranking found this to be due to the pump not priming as the wire going in to the ecu plug was loose and moving with vibration,my friend is an electrician it will still happen on and off and he wanted to know if anything else runs off that circuit that could be affecting it,hope that makes sense electrical stuff really isn't my thing lol
Old Jul 17, 2013 | 12:15 PM
Brads RS's Avatar
Re: ECM help needed
Are you sure that the relay is good. Long crank could be bad relay. Soon as the engine oil pressure comes up the oil pressure switch will kick in (over ride) the relay and the engine will start. Check at your relay connector between green/white and black/white wires should see 12 volts when the key is turned on for about 2-3 seconds. this will tell you that the ecm is commanding the relay on. If it has power there and the relay clicks there is a chance that the contact in the relay are bad. Check for power on the grey wire while the relay is energized to see if contacts are bad.
As for the ecm the only thing on A11 (fuel pump driver) is the fuel pump relay. I have never seen the FP driver go bad on this ecm but i guess it could happen.
Old Jul 17, 2013 | 12:19 PM
stue's Avatar
Re: ECM help needed
All relays are good it was just the fuel pump prime part that was not working,as I said before jiggle the wire and it primes
Old Jul 17, 2013 | 01:42 PM
Brads RS's Avatar
Re: ECM help needed
If jiggling the wire makes it work could be bad terminal connection or bad connector on ecm. Try replacing the terminal first. Delphi #12146448. search mouser.com they have them.
IROCZ1989
Jan 24, 2016 03:55 PM
355tpipickup
Aug 19, 2015 10:02 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
