How to bypass starter enable relay?
Old Aug 4, 2013 | 11:32 AM
Delo93's Avatar
Car: 89 Camaro RS
Engine: 5.0L TBI
I have an 89 camaro that i switched to carb and took out the computer and all the wiring. After doing this, i wired my fuel pump relay to 12v run source and that works fine. However, my car will not crank, which is because i need to bypass the starter enable relay. Ive searched for how to's but the wiring on my relay differs from the how to's i could find. My relay has 2 yellow wires, thick green/white wire, and a thin dark green wire. Can anyone describe to me in detail how to bypass this type of relay?
Old Aug 4, 2013 | 12:29 PM
Delo93's Avatar
Car: 89 Camaro RS
Engine: 5.0L TBI
Re: How to bypass starter enable relay?
Fyi, both yellow wires, and the green/white wire are all thick and same size
Old Aug 4, 2013 | 01:20 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/tech...-i-bypass.html
Old Aug 4, 2013 | 03:53 PM
Delo93's Avatar
Car: 89 Camaro RS
Engine: 5.0L TBI
Thank u for the response... I figured it out already... I spliced the green/white and the outer yellow wire together.
$750 L98
Feb 1, 2025 02:25 PM
thunder57
Nov 7, 2015 02:28 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
