1988 Firebird - Spoiler 3rd Brake Light
Old Aug 14, 2013 | 10:06 PM
scruba's Avatar
Hi all.
My '88 firebird spoiler brake light has simply stopped working. I pulled it apart and checked the globes and contacts but all is fine. I cannot see a separate fuse for this light or at least not a fuse that has blown.
So my question is who has this happened to also and how did you fix it?
Cheers,
Scruba
Old Aug 19, 2013 | 04:42 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Light With No Purpose
The superfluous brake light (clown light) uses the same fuse as the normal brake lights use however it uses a separate contact on the brake light switch.
Using a fused jumper, jump the
yellow wire to the orange wire at the switch.
If the clown light comes on your problem is a defective switch.
If the clown light still does come on make sure there are no breaks in the run of the
yellow wire.
Happy Racing!
I’ll Bump You Once To Move You Over, Next Time I’ll Spin You
Old Aug 22, 2013 | 11:09 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: 1988 Firebird - Spoiler 3rd Brake Light
Did you clean the coontact pad on the interior trim panel just to the left of the pull-down unit? Also check that the contact pins on the hatch is there, clean and not bent.
Lon
Old Jan 16, 2014 | 08:32 AM
rocketforme's Avatar
Car: 1989 GTA
Engine: 350 tpi
Lon
Do you happen to know the replacement bulb # for the spoiler brake light, not for the camaro?
Old Jan 20, 2014 | 10:39 AM
NINÅ's Avatar
Transmission: 765R4
Clown Light
#577 for your 89 Birds’ clown light.
Happy Racing!
I’m Going To Win All My Races In 2014 . . . . . . . . . Or Not
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
stalkier
Aug 13, 2015 12:59 PM
Randomtask2
Aug 13, 2015 01:57 AM
Omega
Aug 10, 2015 12:46 PM
