Fuel Gauge doesn't work
Old Aug 23, 2013 | 02:57 AM
smohmand's Avatar
Car: 1990 IROCZ
Engine: LB9
Axle/Gears: No RPO codes
Hello everyone, I just bought a 1990 Iroc yesterday and the fuel gauge is broken, the needle is always hanging all the way to the right side way past full. Anyone had this problem before or know what it might be?
Old Aug 23, 2013 | 03:05 AM
Spaceboy1980's Avatar
Car: 1990 Camaro RS
Engine: L31
Re: Fuel Gauge doesn't work
I believe all the way to the full side is infinite resistance caused by either a broken wire or a bad sending unit. My 1990 RS had the same issue when I got it.
If you get under the car and follow the wiring out of the gas tank it will lead to a weatherpak connector. Unplug it and use a multimeter and measure the resistance coming from your sending unit. If it is infinite then your sending unit is probably bad. Sending unit replacement sucks... bad.
You can test your gauge by jumping the connector leading to the chassis, just DO NOT jump to the power wire for the fuel pump. It is in the same harness. The gauge should go to empty with the pins jumped.
Old Aug 23, 2013 | 08:00 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
the fuel gauge grounds to the body under the left rear seat.it is possible that all you have to do is clean that ground and ,if you are lucky it will work again.good luck
Old Aug 23, 2013 | 02:19 PM
Car: 1990 Camaro RS
Engine: L31
From the 1990 camaro factory csm:
Old Aug 23, 2013 | 09:04 PM
smohmand's Avatar
Car: 1990 IROCZ
Engine: LB9
Thanks a lot man, I think this should be very helpful I'll try this testing method and see what happens
Old Sep 13, 2013 | 01:41 AM
bigreed91's Avatar
Car: 1990 camaro rs
Engine: 5.0L 305 tbi
What if your fuel gauge reads empty at 1/4 tank and full way past the full mark. As in i run out of gas when it gets to 1/4 on the gauge and when i fill it up it goes past the F.
Old Sep 16, 2013 | 04:42 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Top Fuel
Here’s how to test the fuel gage.
Remove the sender wire going to the gage.
Tape the bare end of the sender wire and put it aside.
Use a potentiometer with a value of 100Ω or the closest you can find.
Connect one end the potentiometer to the gage from the location you removed the sender.
Connect the wiper of the potentiometer to ground.
Turn the key to RUN.
Slowly adjust the potentiometer from 0Ω to 90Ω.
If the gage is bad it will exhibit the problem you have.
If the gage is good it will display a smooth transition from one end of it’s range to the other.
Therefore the problem is with the sender.
You can use a loose potentiometer, or you can throw together a quick little panel like this one.
Happy Racing!
Rule Number 1 Is To Know Which Rules You Can Break
Old Sep 16, 2013 | 05:31 PM
raynehr's Avatar
Car: 1991 Formula Firebird WS6
Engine: 350 SB TPI
Axle/Gears: 3.23 Stockers
If you figure out your sender is bad, I have a cheaper fix for that. Using your old float, and a generic sending unit, I have fixed mine. It takes a little time and some minor fabbing, but it works. I ordered an Equus 9982, fitted it and it works great! The unit is less than 20 bucks, and its a cheaper fix!
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Wade787b
Sep 29, 2015 01:15 PM
justin57
Aug 20, 2015 07:05 PM
