Headlights wont work Low or High beams
Old Aug 25, 2013 | 11:02 AM
ChevyMan9987's Avatar
Car: 1988 Camaro sport coupe T-Top
Engine: 350 sbc
Axle/Gears: 4.11
So one day i noticed that my headlights were out and thought the bulbs were just blown so i bought all new bulbs and no lights. I just replaced my dimmer switch and turn signal switch and still no hi or lo beams i'm stuck i have been trying to figure this out for about a week now and cant seem to correct it had a friend look at it and he thinks it's a short in the steering column. And oh yeah my RPM gauge go wild when i use turns or wipers everything else work fine just headlights wont work
Old Aug 25, 2013 | 03:32 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Headlights wont work Low or High beams
Instead of replacing random parts that might not be faulty at all, might I recommend to pull out a test light and actually find out which part is broken?
This diagram will help you with the troubleshooting to see which wires to check: http://www.austinthirdgen.org/mkport...headlights.jpg
Let us know what you find.
Lou
Old Aug 25, 2013 | 09:25 PM
Engine: 350 sbc
Axle/Gears: 4.11
Lou
well i found what might be the the problem the burn off relay had a few burned pins as well as a melted connector to the dimmer switch that i overlooked as well as wires had been cut by the pervious owner and he did a horrid job of running the fans i just dont know where to start
Old Aug 26, 2013 | 09:33 PM
Engine: 350 sbc
Axle/Gears: 4.11
Had a burnt out dimmer switch the one on sterring coulumn not dash dimmer or turn but be sure you check all power wires and connectors my maf relay and burn off was toast test light is you best firend repete test light is your firend and oh yeah get a cheap electric repair kit from. Walmart its a must have at only 19.99.
Ghettobird52
Jul 5, 2024 11:18 PM
Fronzizzle
Aug 19, 2015 01:36 PM
jackhammer
Aug 15, 2015 10:04 PM
stalkier
Aug 13, 2015 12:59 PM
BBSDesigns
Aug 11, 2015 07:39 PM
