Turn Signal Relay Location
Old Aug 26, 2013 | 03:51 PM
mtaylor102's Avatar
I have an 84 Trans am and recently I noticed the turn signals aren't working and just light up and stay solid if turned on. I am getting I need a new turn signal relay? If so does anyone know an online dealer that sells them and where is the relay located in the car?
Old Sep 3, 2013 | 05:02 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
It’s Your turn
That problem is consistent with one or more burned out or mal-connected bulbs so check all bulbs to make sure they are the correct type, and installed correctly.
A common mistake is people installing 2 filament bulbs 180° rotated.
Now, if they are OK replace the signal flasher.
The turn signal flasher is clipped onto the fuse panel, as delivered from the factory.
However if it has been replaced it might just be hanging in the maze of wires.
It’s round and approximately 1¼” diameter.
The Fuse Panel is located behind a door which is up and to the left of the brake pedal.
You can buy it from any auto parts store be it on line or in person.
Happy Racing!
I Hit The Water Barrels Because My Car Was Dirty
Fronzizzle
Mar 18, 2019 08:29 PM
z28_AJ
Aug 27, 2015 08:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
