Gauges have no idea what they are doing
Old Aug 29, 2013 | 05:19 PM
awildryan's Avatar
Car: 83 Camaro Z28
Engine: 5.7 Vortec 4bbl
Axle/Gears: 3.23 4th gen axle
Hi, do the gauges need to run through the ECM? Because I had a TPI engine, but didn't have the computer so I just did it with a HEI and a carb, but now that I put the gauges in they don't really do much.
For example, most of them don't move, but sometimes the fuel gauge will go from E and just flip upsidedown, or the tach will decide its actually a backlight. And then another time the speedo, which isnt even plugged in just started moving around.
So I was thinking it's either a lack of ECM problem or did I just mess up the wires somehow?
The cars an 83 but the dash and gauges are out of a 91, I already looked up the pinouts for both year gauge plugs, I could have messed them up though.
Thanks in advance, sorry for all the words.
Old Sep 3, 2013 | 05:07 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Color To Same Color Is Correct
The latter.
Even tho pin numbers change from year to year,
colors stay the same.
Connect same
colors together.
You can test/connect thru a fuse at first to make sure you’re not creating a short in the cases of where multiple functions use the same
color.
Happy Racing!
I Hit The Water Barrels Because My Car Was Dirty
Old Sep 3, 2013 | 08:06 PM
awildryan's Avatar
Car: 83 Camaro Z28
Re: Gauges have no idea what they are doing
Thanks so much, all of them work but the tach now, but it's an automatic so eh, Ill figure it out. saved me a lot of time.
Ghettobird52
Jul 5, 2024 11:18 PM
Derick15
Sep 17, 2016 05:28 PM
Wade787b
Sep 29, 2015 01:15 PM
BurlyChev
Aug 16, 2015 09:08 PM
