Wire aftermarket tachometer to lightswitch
Car: 1992 RS B4C
Axle/Gears: 3.23 10 bolt limited slip
Where is the best place to tap into this. I would like my tach to illuminate on/off with the rest of the instrument cluster.
Transmission: 5-speed/T-5
Re: Wire aftermarket tachometer to lightswitch
The easiest spot is likely behind the radio. There is a grey wire there that changes voltage with the dimmer.
Otherwise going to the headlight switch is the other place that works.
Car: 1992 RS B4C
I like this idea. Right where I've already begun pulling other wires. Radio bezel already off so easy enough. Grey wire-got it. I'll give it a go.
Street Lethal
Apr 30, 2019 12:14 PM
ambainb
Apr 25, 2016 09:21 PM
