VSS Replacement - sensor discontinued?
Old Oct 23, 2013 | 05:38 PM
Youngs92's Avatar
Car: 1992 Camaro RS
Engine: 5.0L TPI
Transmission: 5-speed
Hi all,
1992 Camaro RS 5speed. I just went on a long car cruise and my speedo died on my half way through. I have a signal conversion box for aftermarket gauges and the box is telling me its not getting a signal from the speed sensor. I ordered a new sensor from rockauto, which was standard motor products sc12, and this sensor is not the correct one. The part number I have on my old sensor is 10456087, and this part has apparently been discontinued. Does anyone have another part number for this part or can you suggest any solutions besides going through a junker? Thanks in advance
Old Oct 23, 2013 | 05:47 PM
Tinbender59's Avatar
Car: 1997 K1500 SS/SB
Engine: LT1 with TPI on top
Transmission: 4L60E/np241,
Re: VSS Replacement - sensor discontinued?
xx
xx
Old Oct 23, 2013 | 05:48 PM
xx
Old Oct 23, 2013 | 05:49 PM
xx
Old Oct 23, 2013 | 05:53 PM
Youngs92's Avatar
Car: 1992 Camaro RS
Engine: 5.0L TPI
I appreciate the help but unless I have the wrong part for my year, none of those are the right style. Mine is shorter, and has the o-ring on the cylindrical extrusion for the rod that goes into the tranny. It does look like it uses the same connector but that doesn't make a difference if it doesn't fit. Thanks anyway
Old Oct 23, 2013 | 06:01 PM
Youngs92's Avatar
Car: 1992 Camaro RS
Engine: 5.0L TPI
http://www.napaonline.com/Catalog/Ca...218_0354815400
That is the sensor I am looking for, but Napa no longer carries it and I was told they cannot get it :/
Old Oct 23, 2013 | 06:09 PM
xx
Old Oct 23, 2013 | 06:12 PM
xx
Old Oct 23, 2013 | 06:31 PM
Youngs92's Avatar
Car: 1992 Camaro RS
Engine: 5.0L TPI
If you look carefully you will see that the mounting bracket on the sensors you have provided have a slight bend in them and are too large. Also, the o-ring on that sensor is right after the bracket and that section is way larger than will fit inside my transmission. This is another image of the one I need
Old Oct 23, 2013 | 06:33 PM
Ah now I see the problem what they have been showing me is for automatics I'm guessing, let me dig in a little deaper. again I assumed they were the same sorry
Old Oct 23, 2013 | 06:44 PM
look here
http://www.gmpartsgiant.com/parts/gm...-10456087.html
http://oemcats.com/oem-parts/10456087.html
Old Oct 23, 2013 | 06:54 PM
Youngs92's Avatar
Car: 1992 Camaro RS
Engine: 5.0L TPI
Thanks for the links, hopefully one of em still carries the part
Old Oct 24, 2013 | 05:02 PM
Youngs92's Avatar
Car: 1992 Camaro RS
Engine: 5.0L TPI
I may go with a gps speed sender specific for my speedometer instead so I don't have to worry about finding another one if the vss fails again. Does anyone know if the gps sender has to go through the ecm if its meant to output directly to the gauges? Does the ecm need the signal for anything (i don't have cruise control)?
Old Oct 25, 2013 | 09:26 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Yes
If the ECM does not know the speed it will not know when you are slowing down
https://www.thirdgen.org/forums/post...740-post4.html
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
fonzie85
Aug 13, 2015 11:50 AM
mizz0313
Aug 12, 2015 06:45 AM
92purpz28
Aug 11, 2015 02:30 PM
