Wiper AND hi/lo switch?
Old Nov 13, 2013 | 11:49 AM
KnuckleDragger's Avatar
Car: 1989 GTA and 1969 Dodge Charger
Engine: 5.7L...blah! It's a 350 baby!!!
Transmission: Automatic
1989 GTA (just purchased): Turn signal stalk is brand new, but loose and wobbly. The cruise control and turn signals work. However, neither the wipers nor the hi/lo beam function. Does the wiper switch (inside column) also control the hi/lo beams?
AC Delco part#D6380C is the wiper switch.
(PS - wipers will work as long as I push and hold the "washer fluid" tab on the stalk)
Old Nov 18, 2013 | 04:40 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Draggin’ But Hopefully Never Saggin’
If you pull the stalk towards you and it clicks, yes.
If no, observe the bottom of the steering column.
Do you see a switch with a
yellow wire and a light green wire going to it?
If yes, affirmative to the aforementioned, but it’s probably broken or misadjusted.
But your important problem is the wipers so you can drive in the rain.
With the wiper unit unplugged, key in the ACCY position, and the wiper switch in the HI position, use a voltmeter or test light
(the type for testing for voltage, not a continuity tester) to probe the pink, dark green, gray, and purple wires.
Which wires do you have power on?
Happy Racing!
Even Tho I Might Destroy The Car During The Race, At Least It Looks Gorgeous At The Start
wigmobile
Feb 26, 2025 02:56 PM
Veaceonee
Sep 29, 2016 08:15 PM
Randomtask2
Sep 10, 2015 08:37 AM
adelane
Sep 9, 2015 08:51 PM
scottmoyer
Sep 7, 2015 07:06 PM
