battery won't charge?
Car: 1987 Trans Am
Engine: carb. chevy 350
Transmission: 5spd
Hey guys so I was driving home from school the other day and I noticed my volts were pretty low (about 11), I made it home just fine but I can't figure out why my volts aren't somewhere around 14 like they should be. I took the battery and alternator over to napa and had them test it and they said it was good but it still won't pump out any more power, actually the volts have dropped about 1 (down to 10) since I've hooked it back and up ran it a little. The wires look good, and the connections are tight and clean... what else could it be?
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
Re: battery won't charge?
Sounds Like The Alternator Or There Is Something Draining Power After U Park Car. Any InteriorLights Or Manual Fan Switches Left On. Good luck
Car: 1987 Trans Am
Transmission: 5spd
battery wasn't being drained, I think it was a slipping belt, is it possible for the belt to slip but not squeal? the alternator is slightly out of alignment and I'm working on getting it back in line with the other pulleys, the interior voltmeter reads almost 14v now which is pretty normal for the car. My multi meter reads 14.4ish at the alternator which is what it's supposed to be reading. So everything else points to a slipping belt, but that goes to my first question, can it slip without making a sound?
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
Bad ground or loose starter terminals.
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Slip N’ Dip
10-4 on the above gage info by Rusty.
If it was slipping THAT much is would be glazed or smoking, and the loosest belt on the engine.
Check the Alt wires.
The heavier red wire goes from a Fusible Link, to the positive stud, and should have power at all times.
The thinner red wire goes from a different Fusible Link, to terminal S (the sensing circuit) and should have power at all times.
The brown wire goes to terminal F (the turn-on input) from the FAN fuse, and should have power when the key is in the RUN position.
Happy Racing!
Even Tho I Might Destroy The Car During The Race, At Least It Looks Gorgeous At The Start
Happy Racing!
gta892000
Sep 16, 2015 12:37 AM
