Sticky speedo
Old Nov 15, 2013 | 03:41 PM
igende's Avatar
Car: 1988 Firebird
Engine: 2.8L V6
Sticky speedo
My speedo sticks at 50, looks to be of the electronic kind. Anyone experienced this? Wondering if it's the speedo itself or something else causing it. '88 Firebird.
Old Nov 18, 2013 | 02:52 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: Sticky speedo
Could be the motor itself in the cluster, or it could be the needle hanging up which happens sometimes even though its hard to see, the slightest shift can cause that. However if you haven't messed with the needles I would rule that out. Or it could be the speed sensor, but you should throw a code if it were that, by process of elimination I'd say its the electic motor that spins the needle
Old Nov 18, 2013 | 12:30 PM
igende's Avatar
Car: 1988 Firebird
Engine: 2.8L V6
Re: Sticky speedo
Thank you for the follow-up, i'll check the codes see if any were thrown. I have a replacement cluster, so at some point will see about switching out the speedo.
Old Nov 8, 2015 | 03:08 PM
igende's Avatar
Car: 1988 Firebird
Engine: 2.8L V6
Re: Sticky speedo
Quick follow-up since I never posted the resolution. Basically it was a bad Speedo, the needle was sticking. I got a replacement cluster from Ebay and swapped the speedo's. That solved the issue.
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
italiano67
Sep 22, 2015 08:42 AM
TrevinE
Sep 14, 2015 03:20 PM
