Alternator not charging
Old Nov 21, 2013 | 03:50 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
The car is a 92 rs was a 5.0 tbi then was 350 carb, motor went south now has a 350 tpi with holley hp efi. The charging system has worked fine till the tpi was just put in and hasn't worked since the first start-up. I have tried two alternators and they both just tested good. I have power at the red wire and cable and have power at the brown with key on. Dash gauge seems to work right is there a battery light on the dash also? Side notes the factory harness is still in the car but has had some of the un-needed wiring cut out maybe a relay has been removed by mistake? I did swap the big relays on driver-side but didn't help also checked fuses everything looked ok. At this point im at a total loss and have no idea on what else to try.
Old Nov 21, 2013 | 04:22 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: Alternator not charging
Also grounds are very good.
Old Nov 22, 2013 | 10:33 AM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
alts have a "sense" wire alot of times run to a light on the dash, this needs 12v when on or it wont work
Old Nov 22, 2013 | 05:50 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
FIXED I should have said almost all the grounds are good but the main one I needed for the alternator. Long story short had my bracket powder coated and didn't let the ground pass threw. Fix was just run a ground wire from head to alternator.
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
