turn signals not working.
Old Nov 18, 2013 | 11:55 AM
1986_iroc_z28's Avatar
Car: 1986 t-top iroc z28
Engine: 5.0 tpi
Axle/Gears: stock posi and disc brakes
alright, i did a search and didnt really find much. recently got an 87 trans am, it looks great but mechanically is a tad rough.... i havent had the time to look into this issue whatsoever, so i figuered i would post on here thinking maybe someone has had the same problem. well headlights and everthing work, but turn signals and hazards dont work. yet when i hit the brakes, it illuminates the turn signals...... any ideas?
Old Nov 18, 2013 | 12:58 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: turn signals not working.
Try the flasher relay at all? Most of the time its that
Old Nov 18, 2013 | 01:37 PM
Engine: 5.0 tpi
so try putting in a new flasher relay?
Old Nov 21, 2013 | 01:03 AM
6SIX6's Avatar
Car: 89 IROC
yeah try that and see if that resolves the issue
Old Nov 22, 2013 | 08:36 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Your turns and hazards come on at all or are they just lit up and not blinking?
Do you have the tail lights with the 4 red lights on top and the yellow and clear ones on the bottom? If you do, someone may have swapped to different tails in the past and forgot to undo the wiring change under the driver's side kick panel before putting the old tails back...
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
Randomtask2
Sep 7, 2015 05:06 PM
