Electrical Problem 92 RS
Old Nov 29, 2013 | 06:19 PM
diamjim's Avatar
Car: 1992 RS Camaro
Engine: 383
The car has an electrical issue. The car won’t turnover at times. You turn the ignition switch to crank and nothing happens. I pulled the alternator and it tested ok. I pulled the starter and it tested ok as well. I replaced the battery terminals and it gave the same results. Whenever this condition occurs, I can shorten out the starter with ignition key on and the car starts with no hesitation. I had the car looked at by AutoTech and they replaced the battery and positive battery wire to the starter. The car still has the same issue. I determined, the VATS system sometimes blocks the ignition start. If I hit the door locks then VATS system blocks the ignition. I unlock the doors and it starts up. Other times nothing works except jumping the starter.
Car's Background: It's a project car. The owner before me switched it from manual transmission to automatic transmission. The car has a carb.
Old Dec 2, 2013 | 04:52 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Car Is Not Cranky . . . . SO I AM !!!!!!
If it was the VATS the engine would not start even if you use the jumper wire.
That’s consistent with a PO installed Security System.
The VATS doesn’t have to be involved, as some security systems disble starting in other ways besides the VATS.
You can check the wiring on the car to try to locate a PO installed device.
Also, a Security System can disable the ability to start by opening and closing the door, no Key Fob activation is required, which might make you think the problem is sometimes random.
Happy Racing!
I Didn’t Wreck, The Track Moved
Old Dec 3, 2013 | 03:38 PM
diamjim's Avatar
Car: 1992 RS Camaro
Engine: 383
Re: Electrical Problem 92 RS
Nina,
Thank you for eliminating the VATS. What is a PO?
Old Dec 3, 2013 | 05:06 PM
NINÅ's Avatar
Transmission: 765R4
PO = Previous Owner.
Happy Racing!
Old Dec 3, 2013 | 11:33 PM
diamjim's Avatar
Car: 1992 RS Camaro
Engine: 383
NINA, Thank you.
toones
Jan 6, 2016 06:00 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
