Canīt turn off the wipers
Old Dec 1, 2013 | 01:55 PM
DanneZ28's Avatar
Car: Camaro Iroc-Z Z28
Transmission: TH400
Axle/Gears: B&W
Hello
Iīm from Sweden and new here.with an Iroc-z z28 -87
I got some problem with my wipers, canīt turn them off unless i take out the fuse or turn of the ignition, then i do that they wonīt stop in "parking mode"
The wipers delay function doesnīt work to
Washing function is working perfect
Could it be the switch that is the problem?
Iīve got the the workshop manual but that didnīt help
( Sorrry if the english is bad )
Old Dec 1, 2013 | 03:58 PM
ratfink6923's Avatar
Car: 15 Ram, 88 IROC, 92 RS
Engine: 5.0
Axle/Gears: 3.42 (4th Gen)
Re: Canīt turn off the wipers
English was fine! Typically, that is going to be an issue in the wiper motor itself. The wipers are designed to move until they reach "park". if the park switch never opens, they will continue to run. It is possible you could repair the park switch, but if economical, just replace the wiper motor.
Old Dec 2, 2013 | 01:55 PM
DanneZ28's Avatar
Transmission: TH400
Axle/Gears: B&W
i checked the motor today, and all look fine, nothing was loose
In the levelerswitch i feel is a smal "click" between slow and fast but nothing between off and delayfunction
the car has only run 80780mile or 130000km since 87
Old Dec 2, 2013 | 04:54 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Rain Pain
It’s the park mechanism or a bad switch.
Disconnect the wiper motor module connectors C1 & C2.
Have the wiper switch in the OFF position.
Have the key in the ACC position.
Measure voltage on C2a.
Measure voltage on C1b.
They need to be zero.
If you have voltage there the switch is bad, or a wire is shorted to a voltage source.
Din Engelska ar utmärkt OCH Välkommen till Thirdgen.Org
Happy Racing!
I Didn’t Wreck, The Track Moved
Old Dec 2, 2013 | 10:19 PM
DanneZ28's Avatar
Transmission: TH400
Axle/Gears: B&W
I'm going to do some testings tonight after work
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
83 Crossfire TA
Sep 8, 2015 12:06 PM
scottmoyer
Sep 7, 2015 07:06 PM
