remote starter help
Old Dec 4, 2013 | 11:57 PM
Doezsha's Avatar
Car: 1986 Z28 Camaro
Axle/Gears: Stock
Hello every one im new to the forums, "this is my first post" but I have found Alot of useful information here in the past.
My question has to do with hooking up a remote starter unit to my 86 Z28 305 tpi. I installed the unit and got the alarm portion to work, my Power locks didn't work wen I bought the car I replaced the lock switches and actuators... That's another topic tho. So my problem is im trying to figure out which yellow wire near the steering column is the sure for the starter relay . There's a yellow wire on the right side of the column that I tried to use but I can't start the car remotely with that one. Or is it the yellow wire on the left side of the column that's harder to get to and on a smaller harness the one that I need to use. The unit that I have if the Audiovox Aps997c remote car starter. If any one has any info or helpful tips it will be deeply appreciated
Old Dec 5, 2013 | 12:00 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: remote starter help
What's your question?
Old Dec 5, 2013 | 12:17 AM
Doezsha's Avatar
Axle/Gears: Stock
Which yellow wire is the starter relay wire, right or left side of colum
Old Dec 5, 2013 | 06:37 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
The factory yellow wire from the Ign switch is no use to you because it is only hot when the key is in the START position.
You would need a permanent 12V supply to your new relay in order for it to work
Factory 86 wiring
http://92b4crs.tripod.com/86wiring/dia-pics/30-2.jpg
Old Dec 5, 2013 | 07:25 AM
Doezsha's Avatar
Axle/Gears: Stock
Thank you Vettoz I'll give it a try this weekend skyhook I do have a red wire that came with the unit wired to the red wire from the ignition harness.
Old Dec 5, 2013 | 11:02 PM
Doezsha's Avatar
Axle/Gears: Stock
Dose anyone else have any experance with remote starter set up
Old Dec 6, 2013 | 05:24 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Check your local Craigslist, under Services / Auto and look for alarm installers...
I've met a couple good and fair priced ones, and a few over priced ones.... Had great results with the first 2...
Rafael
Old Dec 6, 2013 | 08:00 AM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
you have to wire the start output of the starter to the yellow that goes to the shifter area
Old Dec 6, 2013 | 10:10 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
The instructions seem simple enough.
Pg # 7
http://www.audiovoxproducts.com/docs...APS997C_IM.pdf
You splice the yellow starter wire from your unit into the stock starter wiring somewhere before the P/N switch
See
(Disregard my 1st post above , the unit has it's own power supply for the starter on the red # 3 wire )
Old Dec 7, 2013 | 04:01 PM
Factory 86 wiring
What?
Obviously you've never installed a remote starter, the starter wire is one of the many connections needed for the remote starter to function.
In cases like this where you have to ask which wire to use, I strongly suggest you find someone with experience and pay them to install this for you. This is especially true if your car happens to be a manual, which requires more connections and can be quite a bit more dangerous in the end if not installed correctly.
Old Dec 7, 2013 | 06:29 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by Six_Shooter
Obviously you've never installed a remote starter, the starter wire is one of the many connections needed for the remote starter to function..
If you read my post above I withdrew that comment after the OP clarified what he was actually after.
Your comment should be direct to the OP , I am not the one doing the install ( and I know how to wire cars )
Old Dec 7, 2013 | 08:42 PM
Doezsha's Avatar
Axle/Gears: Stock
It's my first install never wired a car before
Old Dec 7, 2013 | 09:55 PM
There was no clarification needed, anyone with remote start install experience would have known this. My comment is still applicable.
the second comment was directed towards the OP, I figured that would have been obvious.
Which is yet another reason I strongly suggest you find someone with experience to do this for you. Starting with a remote starter as a first electrical project in a vehicle is not recommended, due to the systems and safety concerns involved.
Old Dec 8, 2013 | 05:51 PM
kad5118's Avatar
Car: 91 gta ws6
Transmission: 700 R4 TRANS
Well it would be nice if any one with experience can step and school us on what it take to install the remote starter.Just like the OP i am also looking into doing the same thing.
Old Dec 8, 2013 | 07:45 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Well here's the dilema experienced people (and myself) are in:
1. Know what you're doing or pay someone to do it, if you cant figure it out you should have a professional do it, I did this for a living and I don't suggest anyone with a set of AutoZone crimpers and butt connectors to dive into a remote start.
2 if you do it wrong you can fry the unit, or worse your wiring, there's also a risk involved with an unsafe install (minimal but possible to hook the neutral safety up wrong)
3. my experience is with DEI models, straight forward for me and simple, audiovox has always had some holes in their instructions, to be honest they're usually harder to install, seriously man pay someone to do this for you.
You need to be able to identify the proper wires and components and follow the instructions, this is the bread and butter of installers, its a detail oriented trade, hooking up a radio, subs, sure that's easy. Remote starts have a large amount of connections required, if you can't get it you can't get it. That's all it comes down to, personally I don't feel comfortable getting involved in someone else's install, its a bees nest of problems when something goes wrong.
Old Dec 8, 2013 | 09:44 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
The yellow starter wire will be the thicker yellow wire...just like the other main wires such as 12v constant/ignition/accessory. I do this for a living as well and honestly I could sit here and preach you should pay someone else to do it..but then how are you going to learn.I will do the opposite..if this is something of interest to you to do..practice on your own car first. A car that is very basic..non computer controlled like the camaro or a old honda civic is perfect.Get yourself a cheap multimeter or probe test light.Always test your wires to verify they are what you need them to be,never hook a wire up that you are not 100% sure of its function.Doing so will be a fast expensive way to learn your lesson!. If you came on here and posted that your new to doing this kind of installation..tested your wires and still had an issue with the car not starting,I doubt anyone would fault your efforts.Take your time to do this type of work properly using the right tools/methods and your answer for this would be easily found Good luck and go buy a multimeter and try finding the starter wire the right way.
Old Dec 9, 2013 | 12:45 AM
Doezsha's Avatar
Axle/Gears: Stock
Thank you for your advise. That's why I've been coming to the forums is to learn from others that have more knowledge in the automotive field. I understand the safety concerns.
Old Dec 9, 2013 | 04:39 AM
luvofjah's Avatar
I think the airbag wire is also yellow. Be careful with that too.
Old Dec 9, 2013 | 07:23 PM
Engine: 2005 LQ4
Axle/Gears: 3:54
no airbag in an 86 maro from what I recall
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
