Tail lights / stop lights! Wierd..
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
So I've had my tail lights working for a few months now, tried to figure out how to hook up the stop lights and I get this.... Both stop lights work when the lights are off, when I turn the lights on only the right side works? Kinda wierd..any suggestions?
Here's a video
Here's a video
Re: Tail lights / stop lights! Wierd..
Looks like the tail is wired for the brake light on drivers side Brake is wired to the tail? May be working but it doesn't show over the brighter brake light.
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
I actually pulled out the tail light assembly and pulled the bulbs still connected, I hit the brake and on the right side the brighter filament (stop light) is lit, which is correct and on the left side the duller filament (tail light) is lit, how in the world did this happen and what can I do to fix it? The left side is complete opposite. Need this fixed ASAP!!!
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Got the rear turn signals working now too! Almost there lol
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
I Brake Light 4 No One
Originally Posted by Joe Tag
Unless the bulb is somehow in the wrong way, which shouldn't be possible.
Many people install those bulbs rotated 180°.
To prevent that they should have been engineered a bit smarter with the tabs about twice as long, and the socket made from a harder plastic so it can’t deform allowing the 180° rotation.
Happy Racing!
I Don’t Mind Wreckin’ On The Track, No Paperwork To Fill Out
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
It was hard to get out, I didn't want to break it in my hand trying to pull it out! It went in a lot easier when I turned it 180!
ambainb
Apr 25, 2016 09:21 PM
